Aluminum Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 01-31-2012, 03:11 PM   #1
Rewards Points: 77
Aluminum Wiring
Hi,
My sister's house has all aluminum wiring. She noticed a wall outlet in the kitchen was hot and sure enough the wires at the outlet were overheated and melted the insulation. Now she is worried about all the other outlets etc. We checked all of the other outlets and light switches and snugged up the screws and all looked to be ok. I am considering replacing all of the devices with new ones. I would prefer to use only the type with clamping type terminals and of course approved for aluminum.
I guess another option would be to install copper pigtails with alumicons at each device. I don't see the advantage of doing the copper pigtails because you're just adding that more many connections and adding greatly to the complexity and fill of each box. Short of re-wiring the whole place with copper, the option I like best is to either replace all the devices or just leave it all alone. My sister has lost confidence because of the burned wiring at the kitchen outlet. Any advice from the experts would be greatly appreciated. Thanks
SS396 is offline   Reply With Quote
Old 01-31-2012, 04:58 PM   #2
Rewards Points: 724
use aluminium devices and clean aluminum wire and put some noalox paste so it wont oxidize again
carmusic is offline   Reply With Quote
Old 01-31-2012, 06:00 PM   #3
Electrician
Rewards Points: 780
I would do the copper to aluminum pigtail with the proper marette. I know in Canada aluminum rate devices are expensives($4 or $5 a plug last time I checked)
darren is offline   Reply With Quote
Old 01-31-2012, 06:04 PM   #4
Rewards Points: 13,300
I'd go with carmusic's advice.
Old 02-17-2012, 06:24 AM   #5
For aluminum wiring, of you are not going to pigtail the wires to copper, you must use COLAR recepticals as these are rated for aluminum or copper. These do not have the little holes in the back of the recepticle so you will need to use the screws to attach the wires
pctechguy is offline   Reply With Quote
Old 02-17-2012, 01:02 PM   #6
Rewards Points: 82
I would use these for the pig tailing. You don't have to use AL/CU receptacles.
Connecting 4 aluminum wires in a junction box krick Electrical 3 07-21-2012 03:06 PM
Aluminum Wiring for Range bob22 Electrical 3 07-24-2010 08:38 AM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 03:40 PM
adding copper pigtails to my aluminum wiring was worth it ntomlin Electrical 7 03-02-2009 12:20 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
