Aluminum Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 09-02-2010, 12:07 AM   #1
Aluminum Wire
Is there anything special I need to do when hooking up aluminum wire to a breaker box?
rlaurent79 is offline   Reply With Quote
Old 09-02-2010, 12:46 AM   #2
" Euro " electrician
frenchelectrican's Avatar
Just couple step and ya good to go so here the run down.
DO not nick the alum conductors.
Just brush them very lightly.
Use the antioxide compound { just do not go crazy with this one otherwise it will make a fine mess plus what more they are condtive as well }
Just don't go crazy with toqure the screw or clamp it down like nuts due the alum wires are softer than copper so you have to be little more carefull with it.
That about it unless you have more question to ask us.
Merci.
Marc
Old 09-02-2010, 08:28 AM   #3
Licensed electrician
Rewards Points: 1,628
Probably won't be an issue as most breakers are, but make sure the breaker is listed for use with AL conductors.
Old 09-02-2010, 10:26 AM   #4
Where can I buy the antioxide compound?
Old 09-02-2010, 10:33 AM   #5
A big box store, an electrical supply house or a well stocked hardware store. I have seen small tubes like a travel toothpaste size in the big box stores.
Old 09-02-2010, 12:12 PM   #6
Just about almost everywhere I know in big box store and hardware store and it pretty common item and yes they do have small tube as well if you not going use very much as well.
Merci.
Marc
The Wife said, "The lights are flickering." Dimmer on aluminum wiring Law911 Electrical 4 03-26-2010 11:19 AM
Low Voltage Wire Shorting Rdakota06 Electrical 3 07-22-2009 01:15 PM
Aluminum wire size/ guage / amps? walt1122 Electrical 17 07-30-2008 10:44 AM
Aluminum wire and bonding limbwalker Electrical 10 01-03-2008 05:42 PM
Aluminum wire? Which outlet to use? papashaq Electrical 6 08-27-2007 05:36 PM
