Aluminum Stranded Wire On QO Breaker? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-18-2012, 12:28 PM   #1
Aluminum stranded wire on QO breaker?
Hi,
I just purchased a new Leviton whole-house surge suppressor (model 51110-001): http://tinyurl.com/6rza9xk
It requires a 2-pole 20 amp breaker. I have a Square D 200 amp service panel (house is new -- about 3 years old) and I have installed a new QO 20 amp breaker (model QO220CP) to be dedicated to the surge suppressor connection: http://tinyurl.com/7kxbbub
However, I noticed the Leviton SPD has what appears to be stranded aluminum wires rather than copper which I thought was unusual. Is it acceptable to attach the stranded aluminum wires to the breaker even though the breaker has copper terminals? Do I need to use an anti-oxidant compound on the wires before connecting them to the breaker?
Thanks!
swbrains is offline   Reply With Quote
Old 04-18-2012, 01:12 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
I doubt that is AL.
More likely tined copper.
Nolox not required.
The Following User Says Thank You to jbfan For This Useful Post:
Speedy Petey (04-18-2012)
Old 04-19-2012, 01:01 PM   #3
QO breakers can use copper or aluminum conductors for one-wire applications. if using two-wire terminations (i.e. two conductors on the load terminal), then they must be copper. Stranded or solid doesn't matter.
itsnotrequired is offline   Reply With Quote
Tags
aluminum , breaker , copper , stranded , wire
What size wire and breaker needed? stlouistruckn1 HVAC 4 02-06-2012 09:35 PM
Stranded wire connections at subpanel. woodardhsd Electrical 4 03-18-2011 12:41 PM
20A Breaker, 14 gauge wire? joside Electrical 12 08-25-2010 09:41 AM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 04:02 PM
Stranded wire connections Cossack Electrical 7 03-14-2008 10:56 PM
