Aluminum Sheathed Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 07-26-2011, 12:57 AM   #1
Jack of All Trades
Aluminum sheathed wire
Quick question guys, what cable clamp are you "supposed" to use on flexible aluminum sheathed 12/2 cable conduit? All the ones I have and have looked at at the stores only list steel sheathing. I assume there's a greater crush risk with aluminum, so what do you guys use?
Also, how the heck do you strip this stuff back without harming the wires?
DoctorWho is offline   Reply With Quote
Old 07-26-2011, 01:37 AM   #2
Sparky
Rewards Points: 510
you use one of those or you fold it over until it breaks then pinch the flex off.
there are many different styles of connectors, here is one example..
Techy is offline   Reply With Quote
Old 07-26-2011, 10:56 AM   #3
Rewards Points: 58
Before the tool pictured above was invented, we always used aviation snips. I rarely do/did enough MC work to justify buying this tool. If I had a very big job with all MC cable, I would invest in one. For now the aviation snips (sheet metal snips) work just fine.
J. V. is online now   Reply With Quote
Box fill and wire nuts zephed666 Electrical 7 05-02-2011 01:51 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
Low Voltage Wire Shorting Rdakota06 Electrical 3 07-22-2009 02:15 PM
Aluminum wire size/ guage / amps? walt1122 Electrical 17 07-30-2008 11:44 AM
Aluminum wire? Which outlet to use? papashaq Electrical 6 08-27-2007 06:36 PM
