Old 03-10-2010, 08:43 PM   #1
aluminum service connect
Replaced old copper service with aluminum service 60-amp this old meter has the old style hot water meter next to main meter with a jump wire feeding the hot-water meter main. The new aluminum has to go into the same lug as the hot water meter copper feed. Question? Should I just change service back to copper or can the aluminum and copper stay on the same lug First time I have come across this.
must428 is offline   Reply With Quote
Old 03-10-2010, 09:39 PM   #2
Licensed electrician
Unless the lug is rated for two conductors you cannot install more than one wire in it.
Why are you upgrading the water heater service instead of the house service?
Old 03-10-2010, 09:47 PM   #3
nap
You talking to me?
nap's Avatar
the lug would have to be rated for 2 conductors and rated for having both metals installed together. I am not sure I am understanding what you have but it sounds like basically a meter and the lugs are in the meter base. If so, I do not know of any lugs rated for 2 conductors and have never seen one rated for both aluminum and copper conductors in the same lug
Old 03-10-2010, 09:53 PM   #4
" Euro " electrician
frenchelectrican's Avatar
I just want to make sure I am reading this right you replace the service entrance conductors and did you upgrade the service size or kept at the old 60 amp rating?
Due the old waterheater circuits they are wired for either 20 or 30 amp capacity depending on the control circuits and conductors and the old water heater meters they are pretty much histroy now.
Now to answer your question about copper et alum in one lug the answer is no majtory of resdential meter socket are not rated for two conductors at all unless you got a lug that rated for two conductors { that useally found in 400 amp meter socket or larger }
Merci,Marc
Old 03-11-2010, 12:23 PM   #5
Yes this is the original meter can back then they had two on one lug that was the way it was when I opened it and it was original wire never touched in 50yrs. Weird back then I guess.
I looked at another house same time period same thing. One for the hot water meter one for the house meter. Was this way all this time no problem, service wire outside just aged thats why I opened it, inside box great shape for the age. Thats why I ask the question about alum on copper I know thats a no-no but the system did have the copper service wire and the hot from that going to feed the hot water meter. I ran the new aluminum service before I opened it saw how they did it back then, thats when I saw this two on one it is a large lug opening made for it. Guess best thing go back to copper.
Old 03-11-2010, 12:42 PM   #6
If your socket has lay-in ligs they are for one conductor only, even if both wires are the same material.
Some sockets will allow two individual lugs on the same stud.
Service mast options bsperr Electrical 6 12-09-2009 09:48 AM
Remodel - Moving from 200 amp service to 320 amps stevedar Electrical 20 11-29-2009 09:14 PM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 11:31 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
