Aluminum Foil Knob And Tube - Electrical - DIY Chatroom Home Improvement Forum
Old 03-07-2011, 05:31 PM   #1
Originally Posted by tgiosan View Post
I have knob and tube wiring that seems like it is just aluminum foil covered in paper. Does anyone have any reference to this method? Also they are connected to PINCO type TD16 fuses. DOES anyone have any reference to PINCO or TD16 fuses?
Do you live in the US or Canada? Or perhaps El Salvador?
Old 03-07-2011, 05:32 PM   #2
Learning by Doing
Leah Frances's Avatar
Picture or it didn't happen.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 03-07-2011, 05:33 PM   #3
waterman1971's Avatar
Rewards Points: 150
Hahaha! That tickled me!
waterman1971 is offline   Reply With Quote
Old 03-07-2011, 05:39 PM   #4
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
Funny, when I was a kid I used to play a lot with electricity. I learned a lot, well, anything not having to do with safety. I would crunch foil up into "wires" and shove it in the socket. Had circuits with light switches (most of them I had made of paper and foil, folded and stapled together). It worked, but when something went wrong, it was not pretty. Well actually it was pretty cool. The whole contraption turned all blue and stuff and it smelled very funny.
I would get that wiring pulled out and install new wiring.
Old 03-07-2011, 08:33 PM   #5
Rewards Points: 1,418
I have knob and tube wiring that seems like it is just aluminum foil covered in paper. Does anyone have any reference to this method?:fuses?
I have never heard of this. Unless someone actually burned out the wires in the house from overcurrent (putting a penny under the fuse) and had to do a makeshift rewiring job.
Old 03-08-2011, 02:55 AM   #6
" Euro " electrician
frenchelectrican's Avatar
TD16 sound like Daized fuse but need the photo to make sure due I am in France and I have see plenty Americiané et Europeané fuses so I should able dail it in quick.
So .,, Photo please this is the only way you can get correct answer from us.
Merci.
Marc
Old 03-08-2011, 08:44 AM   #7
Household Handyman
Rewards Points: 1,408
Why is this "tgiosan" so adverse as to posting photos in his/her posts?
Old 03-08-2011, 08:58 AM   #8
Wire Chewer
Rewards Points: 46
I am in massachussets NOT CANADA WHY WOULD YOU THINK THAT?
You're saying that like it would be a bad thing.
Old 03-08-2011, 09:52 AM   #9
Learning by Doing
Probably because we were guessing because you don't have your location in your profile.
Old 03-08-2011, 09:55 AM   #10
From your description of the wiring, it seems to be what is found in 3rd world counties!
Old 03-08-2011, 01:23 PM   #11
Rewards Points: 1,522
"the fuses were made by edison..."
Hold onto them; they're collector items.
bob22 is offline   Reply With Quote
Old 03-08-2011, 01:32 PM   #12
Learning by Doing
I suspect troll.
Old 03-08-2011, 01:34 PM   #13
the fuses were made by edison and my friend just told me about them
Jeez, lighten up man.
Mike in Arkansas is offline   Reply With Quote
Concrobium and knob and tube wiring WillK Electrical 13 02-28-2011 01:17 PM
looking at a house with "some" knob and tube shaner123 Electrical 8 02-08-2011 05:56 PM
Knob and tube neutral question gbwillner Electrical 2 11-07-2009 10:34 AM
knob and tube question marin001 Electrical 7 12-21-2008 04:49 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
