Aluminum Conduit And Steel Fittings - Electrical - DIY Chatroom Home Improvement Forum
Old 12-06-2010, 08:39 AM   #1
Aluminum Conduit and Steel Fittings
When an electrician installs an aluminum mast in a steel meter base and more aluminum down into a steel LB fitting, isn't there a corrosion issue due to dissimilar metals? Are there aluminum fittings?
Melanie337 is offline   Reply With Quote
Old 12-06-2010, 10:16 AM   #2
Rewards Points: 1,014
This may help. Can you spot the problems here though?
NEC 2008
344.14
Dissimilar Metals. Where practicable, dissimilar metals in contact anywhere in the system shall be avoided to eliminate the possibility of galvanic action. Aluminum fittings and enclosures shall be permitted to be used with steel RMC where not subject to severe corrosive influences
1) I don't know what Code generation is applicable to your area
2) This speaks of AL conduit bodies and steel Rigid Metal Conduit (RMC). Your case is the opposite.
Anti-wingnut is offline   Reply With Quote
how to extend flexible steel conduit run titan7 Electrical 5 08-31-2010 10:29 PM
conduit coming out of the ground, or exiting building near the ground wmldwilly Electrical 10 05-24-2009 04:44 AM
PVC Conduit and steel box Question???? houstonbrama Electrical 4 08-07-2008 11:56 AM
conduit and fittings analogmusicman Electrical 16 05-10-2008 12:30 PM
Conduit Fill & Ampacity capndave Electrical 37 03-26-2008 02:16 PM
