#1 |
Aluminium wiring.
Have some plugs that have aluminum wires in them. I am trying to upgrade to deco style plugs (square style). Does anyone know if it would be bad to use the copper plugs.
J |
#2 |
Aluminium wiring.
Do not do it. the connections will corrode and cause an arc.
Look for switches made just for aluminum wiring. There clearly marked in any home center or electrical supply house. There will be the letters AL on the side of them. |
#3 |
Aluminium wiring.
That's what I thought.
Would you happen to know where I can buy the square deco style plugs |
#4 |
Aluminium wiring.
Your in Canada and I'm in the US no idea what's avalable in your area.
#5 | |
Master Electrician
Aluminium wiring.Quote:
http://www.pelicanstate.net/Download...The%20Home.pdf |
#6 | |
J |
#7 |
liscenced electrician
Aluminium wiring.
Whatever you do, make sure to use an approved grease.
#8 |
Licensed Electrical Cont.
Aluminium wiring.
Can you explain a bit more about this?
Sometimes I feel like if I answer any more questions it is like someone trying to climb over a fence to jump off a bridge and me giving them a boost. |
#9 |
Aluminium wiring. |
#10 |
Aluminium wiring.
I have never seen Decora fixtures for al wire, but they may exist. One way to use them would be to use a copper pigtail, and wirenut with al approved wirenuts and no-ox or similar grease.
As suggested in the link on one of the posts, the wire is not the problem, the fixtures that the wire connects to is the problem. Always look for AL compatible fixtures. |
#11 |
Aluminium wiring.
http://www.westsidewholesale.com/ele...on-1755-w.html
Leviton makes side screws on there switches that can use copper or aluminum. |
#12 |
Aluminium wiring.
Aluminum oxidizes without any grease. Eventually making a poor connection. Most aluminum rated connectors come with grease in them, but if it doesnt, its easily over looked by a homeowner and imo its the most important precaution with aluminum
#13 | ||
That is why he questioned you. |
#14 | |
Second, it is not required by code, but it is a good idea for larger conductors. Third, You MUST use the proper device or connection for small AL conductors. Lastly, AL conductors never come with anti-ox already in/on them.
#15 |
Aluminium wiring.
If I do the copper pigtails to the plug using the aluminum to copper maretts should I do the same with the ground wire
| Display Modes | |
| Cloth Wiring - Replace? | JessicaGus | Electrical | 9 | 09-23-2009 07:45 PM |
| electric wiring in house remodel | wis_remod | Electrical | 6 | 04-02-2009 03:40 PM |
| Wiring diagram for three-way switches with pilot light | SaxTeacher | Electrical | 33 | 03-18-2009 08:11 PM |
| New Home Wiring - Seeking Expert Advice | Dirtrnr | Electrical | 3 | 02-10-2009 11:33 AM |
| Aluminium Wiring Several Questions | Chemist1961 | Electrical | 6 | 01-18-2009 10:40 PM |
