Old 11-29-2012, 01:19 AM   #1
Alternate wire sizing
If 1/0 THHN is rated at 150 amps @75 degrees and #4 THHN is rated at 85 amps. Can I runs 2 strands of #4 in place of 1 length of 1/0. Technically it would handle even more amps than 1/0. It's a short run.
granitefan is offline   Reply With Quote
Old 11-29-2012, 05:17 AM   #2
A "Handy Husband"
rjniles's Avatar
Not code compliant.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 11-29-2012, 05:20 AM   #3
Licensed electrician
Wires need to be larger than 1/0 before they can be paralleled.
sizing electrical wire for amps vmw Electrical 12 12-23-2011 05:27 PM
Sizing and best way to run wire for sub panel cschwer Electrical 13 07-14-2010 09:11 AM
replacing 3 wire to 4 wire compressor fan - please advise! frazwr01 HVAC 2 06-27-2010 11:44 AM
Wire Sizing shastaron Electrical 40 02-03-2009 08:47 AM
wire sizing for wall heater? gerhops Electrical 22 09-21-2008 10:59 PM
