Alltmonster - Electrical - DIY Chatroom Home Improvement Forum
Old 12-09-2004, 11:25 AM   #1
alltmonster
can someone explain or tell me a website to look on on how to wire a ceiling fan up so that the fan can be turned off and on by a switch and the lights can be turned on by the pull chain????
allymonster is offline   Reply With Quote
Old 12-10-2004, 07:52 AM   #2
all you have to do is wire the fan to the switch and wire the light to direct power. there should be two separate wires for the fan and light power. So, you'll have power from the switch powering the fan with either the red wire or black. Then take whichever wire is left(red or black that you didn't use) and connect that to the power source before the switch so it is live all the time.
Hammertime is offline   Reply With Quote
Old 12-10-2004, 10:22 PM   #3
Contractor
To get the two to operate independently you will have to run a wire, if it is a new home it will be there, from the line side of the switch to the light (blue). This wire has to be black or tagged as such.
Your other alternative (suggested) is to spend about $35.00 on a remote control system that allows you to control everything from wherever you are.
Teetorbilt is offline   Reply With Quote
Old 02-13-2005, 10:56 AM   #4
Excuse my ignorance, but after turning the switch on, wouldn't you just turn the light off with the pull so that the next time you use the switch, only the fan comes on?
katzpjs is offline   Reply With Quote
Old 02-14-2005, 02:46 PM   #5
Rewards Points: 150
make sure you read the directions thoroughly. Each of the ten fans I've installed detailed several wiring scenarios - including the one you want. You can also check the manufacturers website - usually listed somewhere on the packaging.
pipeguy is offline   Reply With Quote
Old 02-14-2005, 03:39 PM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 464
Before I expalin how it can be done, I need to know how it is wired now. Are you replacing a light with the fan, installing a new fan where nothing exsited before, or replacing and exsiting fan and would like to control it differently?
jbfan is online now   Reply With Quote
Old 02-16-2005, 09:53 PM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
What jbfan said.
It has all to do with what's in the ceiling and on the wall. Then we can tell you how to wire it.
I agree the easiest thing it to use a remote conversion, although I don't like them.
Old 02-16-2005, 09:54 PM   #8
I just realized this post is 7 days old. I guess he forgot he posted this here.
