Allowed To Run More Than One Romex Cable Through A Single Hole In A Joist? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-15-2007, 12:34 PM   #1
They're all fixer-uppers
J187's Avatar
Rewards Points: 516
Allowed to run more than one romex cable through a single hole in a joist?
My brother is running some 14-2 romex in his house. He needs to pass 6 or 7 romex cables through a joist and down toward the basement. Can he run more than one cable through a single hole? If so, how many? Thanks
J187 is offline   Reply With Quote
Old 08-15-2007, 12:51 PM   #2
I think the questions should be really , how large the hole can be drilled without affecting the structure...
it should be as many cables as the hole can hold.
when I did my basement, I have some place where need to fit a lot of cables to different holes.... I see no reason there will be any danger to anything...
KUIPORNG is offline   Reply With Quote
Old 08-15-2007, 04:21 PM   #3
J187's Avatar
Rewards Points: 516
Is it in code to allow as many cables as the hole will allow?
Old 08-15-2007, 05:59 PM   #4
weekend warrior
Rewards Points: 150
It's been 5 1/2 hours since you asked.... you could have called the inspector and had an answer in 30 seconds... I mean, that is why you waste, I mean, pay the permit fee for....
I prefer many smaller holes spaced a few inches apart in the center of the member, rather than a big 'ol hole with a half-dozen cables....
johnny331 is offline   Reply With Quote
Old 08-16-2007, 11:04 AM   #5
walt1122
Rewards Points: 334
Don't quote me on this and as another message suggested you might want to run this question by the electrical inspector... But a rough rule of thumb is that if you have any troble threading the wire throught the hole it's too full!! they should be loosely run to keep them from getting too hot. Electricity gives off heat. Heat = resistance, resistance = more heat... you get the idea. And if you need to add more holes better pose this question to the inspector too. Don't want to weaken the structure by placing the holes to close or to low.
Walt
walt1122 is offline   Reply With Quote
Old 08-16-2007, 11:54 AM   #6
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Code does not directly address the number of cables that can pass thru a bored hole. The consideration for this has to do with deration and/or bundling. You will see all kinds of residential installations where there are 8,9,or 10 nm's run through a bored hole. There is even code that allows a conduit coming from a panel to be filled with nm's for not more than 10 feet under the right circumstances. In my area most inspectors don't like to see more than four 14/2 G or four 12/2 G through a bored hole. The reason for this is that if you were to derate the ampacity of the cables you still will maintain the 15 or 20 amps respectively for the wire guages. Over four 2 wire conductor cables and you would have to reduce the branch circuit ampacity if your inspector considers this to be a deration issue. Multiwires of 14/3G or 12/3G are essentially the same as 2 wire conductors as you do not have to count the neutral for deration purposes.
Hole size must be considered in joists... building codes allow a hole to be drilled any where on the joist as long as it does not exceed 1/3 of the joist depth. The bored hole must not be closer than 2 inches to the face edge of the joist. Generally........
2x6......bored hole max dia....... 1 13/16"
2x8......bored hole max dia....... 2 7/16"
2x10... bored hole max. dia...... 3 3/16"
2x12... bored hole max. dia...... 3 3/4"
As a side note in my experience where ambient temperatures are not overly exceeded like in an attic in Arizona when its 106F outside I don't believe 6 or 7 14/2's will be an issue as long as you don't have very high temperature considerations. If it is possible drill two holes then the problem goes away.
Stubbie
Old 08-17-2007, 07:36 AM   #7
J187's Avatar
Rewards Points: 516
Stubbie, Awesome info. I knew deration could be a consideration, but I wasn't sure at what point it became an issue. This helps immensely, Thanks. He will be very happy to see all those guidlines laid out for him.
JOHNNY - He tried, the inspector wouldn't give a clear response.
Old 08-17-2007, 08:46 AM   #8
In my area... questions normally not go to inspector directly, as I understand... they are very busy and really difficult to answer phone calls... rather... it goes to the office people and they direct it to some sort of code knowledable people then come back with an answer... this all through emailing... I asked quite a few questions when I renovating my basement, they all got answered politely... but some answer is fast, some is not that fast... but not right away for sure...
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 02:54 PM
Cutting/drilling hole in joist - How big? curls00 Carpentry 3 07-20-2007 09:56 PM
Romex laying across joist in attic? Doug Crf Electrical 4 08-17-2006 04:53 PM
Any way to allow a 3.5" bore through a 2x10 floor joist? peeks Building & Construction 1 07-06-2005 02:02 PM
