Allen West Scf Starter - Electrical - DIY Chatroom Home Improvement Forum
Old 07-08-2008, 03:36 AM   #1
Hi Does Anyone Know How To Wire An Old Allen West Scf Starter ,i Need To Know What The Input Single Phase Wires Connect To And What The 3 Phase Output Wires Connect To .
The Terminals Inside Are Marked L1/l2/l3/c Those Terminals Are On The Top,and On The Front Above Each Dashpots Is Marked A/b.
The Starter No Is J949b36
Hp .5
Volts 200-250
Amps 3.5/4.2~50
Thats All The Info I Can Give So If Anyone Can Help Its The Stop/start Switch For My Compressor, Any Help Would Be Appreciated Thankyou
rummins is offline   Reply With Quote
Old 07-08-2008, 10:41 AM   #2
Rewards Points: 204
Your not in the US right? I Googled your starter and found zero. Tell me what you are trying to do and I might be able to help you. If you are converting single phase to three phase, I can hook you up in a snap.
Old 07-08-2008, 02:53 PM   #3
hi i could not find anything here either and no im in the uk.my starter that came with the compressor states PH1 on the side so i presume that means single phase but the motor is 3 phase ,so i was guessing that its single phase feed which the starter then transforms to 3phase output.
the compressor is a 1970s atlas capco with a danfoss regulator
fix my Lawn Mower Starter myself !!! KUIPORNG Landscaping & Lawn Care 10 06-28-2009 01:34 PM
scf starter wireing help needed rummins Electrical 6 06-20-2008 04:41 PM
replacing starter boards Bob C Roofing/Siding 6 07-17-2007 12:04 PM
CertainTeed starter shingle ? MACCC Roofing/Siding 2 04-20-2007 02:26 PM
No starter strip!?! hockeyhead Roofing/Siding 10 09-17-2005 11:54 AM
