-   -   Allen West Scf Starter (http://www.diychatroom.com/f18/allen-west-scf-starter-23338/)
rummins 07-08-2008 04:36 AM
Hi Does Anyone Know How To Wire An Old Allen West Scf Starter ,i Need To Know What The Input Single Phase Wires Connect To And What The 3 Phase Output Wires Connect To .
The Terminals Inside Are Marked L1/l2/l3/c Those Terminals Are On The Top,and On The Front Above Each Dashpots Is Marked A/b.
The Starter No Is J949b36
Hp .5
Volts 200-250
Amps 3.5/4.2~50
Thats All The Info I Can Give So If Anyone Can Help Its The Stop/start Switch For My Compressor, Any Help Would Be Appreciated Thankyou
J. V. 07-08-2008 11:41 AM
Your not in the US right? I Googled your starter and found zero. Tell me what you are trying to do and I might be able to help you. If you are converting single phase to three phase, I can hook you up in a snap.
rummins 07-08-2008 03:53 PM
hi i could not find anything here either and no im in the uk.my starter that came with the compressor states PH1 on the side so i presume that means single phase but the motor is 3 phase ,so i was guessing that its single phase feed which the starter then transforms to 3phase output.
the compressor is a 1970s atlas capco with a danfoss regulator
