All Switches/lights And Outlets In 1 Room Stopped Working - Electrical - DIY Chatroom Home Improvement Forum
Old 04-28-2011, 06:13 PM   #1
All switches/lights and outlets in 1 room stopped working
The two lights and outlets in my bathroom stopped working suddenly. I checked breakers and nothing seemed wrong and am not sure how to proceed. i read somewhere that a bad neutral could cause this issue. But how do I check which is the faulty part? Should I verify that the wiring on all outlets is correct/not broken?
Please advise
am2011 is offline   Reply With Quote
Old 04-28-2011, 07:18 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 142
Check for a tripped gfci.
jbfan is online now   Reply With Quote
Old 04-28-2011, 07:33 PM   #3
NACE Coating Inspector
mustangmike3789's Avatar
sounds like a bad outlet upstream, probably one of those outlets feeds everything else. gfci as mentioned already could be it too.
mustangmike3789 is offline   Reply With Quote
Old 04-28-2011, 08:00 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
deleted
Coastal South Carolina
Old 12-23-2011, 08:52 AM   #5
Please advise
probably open wire weather neutral or hot leg.
first
find circuit feeding those few lights. turn circuit back and work in direction tpward electrical panel and try tapping lights and rec.outlets with hand to see if lightflickers .if it does than check that outlet for a loose wire (either on screw terminal of wire cap. if that doesnt work just open lights andf fixtures toward panal as suggested. I use to put a buzzer in outlet not working so I could hear it if problem was in another room. Also use your nose and smell the outlets close to ones that dont operate the burned will smell like a burned pot handle or burned wire
paulat120 is offline   Reply With Quote
Old 12-23-2011, 05:28 PM   #6
dmxtothemax's Avatar
Rewards Points: 5,098
Please advise
Do you know which circuit breaker feeds these lights & recepticules ?
Is there anything else on the same circuit ?
Does the other things still work or not ?
You need to answer these questions so we can find out where
the power originates from !
dmxtothemax is offline   Reply With Quote
Old 12-24-2011, 10:06 AM   #7
if it is a new house or a recently renovated bathroom . check gfci rec in bathroom .It could be feeding those rec and light .check gfci in other bathroom . It could be feeding both baths
Circuit stopped working, breaker did not trip nr5667 Electrical 7 07-08-2012 04:31 AM
bathrooms and outdoor outlets not working maybecalifornia Electrical 1 03-04-2011 07:24 PM
new basement room circuit BlueBSH Electrical 9 09-03-2010 09:44 AM
Bathroom and Adjacent Breakfast room outlets non functioning jterp7 General DIY Discussions 7 06-14-2010 12:29 PM
Outlets stopped working RammsteinNicCage Electrical 12 05-03-2009 10:47 PM
