Alarm System Contacts - Electrical - DIY Chatroom Home Improvement Forum
Old 06-30-2012, 02:23 PM   #1
alarm system contacts
I need to replace the recessed contacts on window to self adhesive ones on the outside of the window frame. Wire was 4 wire going to 2 wire coming from recessed contact and spliced. Do I just connect the 4 wire on one end and add new connectors with 2 wire and splice those together. Seems doing that woule close the circuit. Does anyone know if this is right
sharonborden is offline   Reply With Quote
Old 06-30-2012, 04:44 PM   #2
Rewards Points: 87
Would need more info about system to advise. Most alarm systems are "closed" circuit and a continuity tester would verify this for you.
Why can't you just install the new switch the same as the original?
The 4 wire conductor may only be using 2 conductors for this switch with the other 2 wires for another switch.
George6488 is offline   Reply With Quote
Old 06-30-2012, 06:02 PM   #3
Rewards Points: 320
Not sure what you mean by mounting on the outside of the window. The contacts need to go on the inside of the window so that they cannot be tampered with. Did the contact that is on the window go bad? Most window contacts will be only two wires and set up as normally closed. Post a picture or more information and we can help.
teamo is offline   Reply With Quote
Old 07-25-2012, 10:11 AM   #4
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Originally Posted by homealarms
Install yourself professionally driven budget alarms of superior quality from us at competitive prices and get security alarms monitoring system, best home alarm systems.
As stated in the rules for posting, advertising is prohibited.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 10-09-2012, 04:34 AM   #5
pacowilson's Avatar
For the majority of magnetic contacts, it only with 2 wires for the connection. don't know exact wiring method, but it should be very simple. After finish the wiring, just using the multimeter to test the circuit.
Please note that the hard wiring requires EOL resistor wiring, know more about EOL resistor:
http://www.hkvstar.com/technology-ne...-resistor.html
pacowilson is offline   Reply With Quote
Wired alarm system Cdessel Electrical 2 11-08-2011 09:15 AM
Installing Pool System New v. Used? flowerchick General DIY Discussions 5 10-27-2011 08:28 AM
New House, new system, poor cooling Faulknertw HVAC 15 07-08-2008 11:06 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
Size A/C system properly 70stang HVAC 1 03-26-2006 08:22 PM
