Alarm System - Electrical - DIY Chatroom Home Improvement Forum
Old 01-04-2014, 04:55 PM   #1
Alarm system
Installing ext. siren to Simon XT
marcurt is offline   Reply With Quote
Old 01-04-2014, 06:13 PM   #2
Rewards Points: 744
Cool story.
Seattle2k is offline   Reply With Quote
Old 01-04-2014, 07:44 PM   #3
Presumably you are seeking help?
I have limited alarm/electrical experience, as well as limited knowledge regarding the subject. I have a Simon XT and have done some preliminary research, which I will do my best to accurately convey, however I do not know the accuracy of the information itself.
Here are a few posts that I bookmarked related to the issues (all found simply by Googling - the DIY Security/Alarm forums are great):
http://www.doityourself.com/forum/el...al-sirens.html
http://www.diyalarmforum.com/board/i...?topic=15543.0
http://www.diysecurityforum.com/index.php?topic=29482.0
The Simon XT does not guarantee enough power (primarily when on battery backup) to drive most/normal external sirens. As such, it is not recommended to rely on the units internal power feed to drive large external sirens.
Option 1 - There is one external wired GE siren that it can drive, but I have read that it is not that loud compared to 'real' external sirens due to the required low power consumption.
Option 2 - Use a self-powered wireless siren. I haven't looked into this much, but a Z-Wave siren was recommended by my alarm installer. I assume they would need their own power & battery backup, and are triggered wirelessly.
Option 3 - Someone also recommended small low-power piezo speakers (from Radio Shack) which are supposed to be low enough power that you can use a few of them, and also supposed to be very loud for low-power device.
Option 4 - There are ways to wire a relay switch such that the siren draws its own power directly, and the switch turns it on based on the signal from the control panel. I think one of the links above starts to get into the details of this. Doesn't sound terribly complicated, but the information I found may be a bit vague/incomplete for someone without much prior knowledge (like myself). I think adding battery backup to this type of system is another adventure entirely requiring more substantial electrical skills and knowledge.
Anyway, that's all I've got for you, hope it helps. I found enough information to discourage me from proceeding - for now. My ultimate plan is to wire an external siren up into my attic across the house from the control panel (as a decoy), so I can hide the panel and confidently reduce my monitoring to 'regular' rather than 'deluxe' (which prevents smash-and-grab for additional $$)
greenfrog5 is offline   Reply With Quote
Old 01-05-2014, 11:20 PM   #4
Alarm system
Originally Posted by Seattle2k View Post
Cool story.
Thanks Seattle, I`ll try to follow info provided
Alarm System Cultcab General DIY Discussions 22 06-04-2013 11:59 PM
prewired alarm system indep Electrical 2 12-17-2012 12:07 PM
Need help with finishing touches on radiant heat system gbwillner HVAC 6 12-03-2011 12:16 PM
Security alarm system ela Electrical 14 11-12-2011 01:17 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
