AL Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 03-11-2008, 08:01 PM   #1
Master Of Nothing
mr500's Avatar
Smile
AL Wire
Just wondering something. Do you HAVE to use the anti-oxidize gel (whatever you call it) on Al wires when connecting it into panels etc.?? Some say that you must others have no opinion??
Mike
mr500 is offline   Reply With Quote
Old 03-11-2008, 09:13 PM   #2
Electrician's Helper
Pudge565's Avatar
Rewards Points: 150
Send a message via AIM to Pudge565
yes otherwise it will oxidize and you will get a bad connection if i'm not mistaken possibly leading to a fire due to the connectiong getting hot.
Pudge565 is offline   Reply With Quote
Old 03-11-2008, 09:42 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,990
This is true, but it is not in the code book.
I think "110.11 Deteriorating Agents" would be the closest thing, but this is not nearly specific.
Old 03-11-2008, 09:43 PM   #4
Master Of Nothing
mr500's Avatar
Ill add sum just the same. Just be my luck something will happen!
Mike
Old 03-11-2008, 09:47 PM   #5
Absolutely. It's not worth not doing. Does that make sense?
Old 03-11-2008, 09:53 PM   #6
Master Of Nothing
mr500's Avatar
yeah actually it dores 100%. Could have told the guy who wired up my feedes that it takes just as much time to do it wrong as it does to do it right.
Ill be adding some when I wire up my garage unit. As well adding some to the feeders to my house that HE SHOULD have done.
Is this stuff clear? Maybe he added some that I don't see? Dont really know what Im looking for though
Old 03-11-2008, 10:02 PM   #7
Not typically.
Usually it is a grey paste. Like the consistency of smooth peanut butter.
I do have some new clear blue stuff my supply guy gave me to try, but I have not seen anyone else using it yet.
Old 03-11-2008, 10:29 PM   #8
Master Of Nothing
mr500's Avatar
ok sounds good. thanks for all advice
Mike
Old 03-11-2008, 11:10 PM   #9
Idiot Emeritus
Rewards Points: 1,492
Another thing it does is sort of lubricate the end of the setscrew where it presses the wire. This allows for a much tighter connection, and doesn't gall up the wire where the setscrew turns on it.
One of the main problems with AL wire is 'cold flow'. Any setscrew AL connection will loosen up in time, even with no current on it. Aluminum is a soft metal, and pressure on it will make it move, even if it never heats up.
Another problem is 'spot heating'. This is usually not much of an issue on a house feeder, but it a big problem on a motor feeder. The starting surge current of a motor will cause the termination to heat up quickly, and thermal expansion will cause the connection to loosen. Anti-oxidant compound helps this alot by distributing the heat over a larger area, thus limiting spot-heating.
When making a termination with AL wire, wiggle the wire as you are tightening it, you'll get another half-turn or so out of the setscrew. A much tighter connection.
Rob.
micromind is offline   Reply With Quote
Old 03-11-2008, 11:19 PM   #10
Master Of Nothing
mr500's Avatar
ok well do that as well..working with 2-2-4-6 so hopefully it wont be that bad. Thanks 4 all advice!!!
Mike
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
Can you wire a 3-way circuit with 2 wire + ground mnyman2003 Electrical 8 12-04-2007 08:23 AM
Stove Top wire capt2 Electrical 8 10-05-2007 01:41 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
Does a 6 x 12ga wire nut exist? peeks Electrical 1 10-02-2005 09:58 AM
