AL splice
1 Attachment(s)
I dont think i can go this route but will ask before i end up buying another extremely long piece. If i have # 4 AL bare ground going from neutral bar to copper water pipe and need to extend the Al wire can i use this Al splicer wire lug ? or any other approved AL connector .Attachment 61101
Are you upgrading this service or what ?
Normally I use compession connection that is the only thing I ever use on larger alum espcally with EGC ( electode grounding conductor ) I know there are other approved items but it depending on your state/provice is. Merci, Marc |
The GEC must be continuous from the main disco to the electrode (whether its the rods, water, ufer, building steel...). I know you can purchase irreversable crimp connectors that would allow you to extend the wire, but the cost of the crimper is more than a new run of wire.
From NEC 2008:
1 Attachment(s)
is this the type id needAttachment 61145
| All times are GMT -4. The time now is 11:58 PM. |
