AL Pull Elbows - Electrical - DIY Chatroom Home Improvement Forum
Old 02-25-2009, 07:58 PM   #1
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
AL pull elbows
This may be a stupid question, but here goes, the Aluminum pull elbows (LL, LB) that are made for RMC. Do they fully maintain the integrity of EMT, interms of it's bond? (meaning with one of the LL's installed it is still a fully functional & legal fault path correct?) (I know it is a metal on metal connection, so I am sure it will be functional, I am wondering more about if it is legit)
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 02-25-2009, 08:05 PM   #2
Rewards Points: 2,350
Jamie
LL, LR, LB etc, are conduit bodies, and are a different beast than pull elbows, just so you know. But yes, they are as valid a connection as a conduit fault path can be.
Old 02-25-2009, 11:59 PM   #3
DIY'er
jamiedolan's Avatar
By what home depot stocks, you'd think everyone uses plastic conduit for everything. They only have LB's in metal, but lots of options in plastic.
I'll check my local hardware store. Otherwise there is a supply house that I can buy from, a couple of the things they have quoted me on have been way more than they should be, so I have bought most stuff retail.
Jamie
Old 02-26-2009, 08:36 AM   #4
Rewards Points: 506
Send a message via AIM to theatretch85
Jamie
I'd imagine they are quoting you more because you don't have an account with them or are buying too little so they are probably charging you a handling fee of sorts. As far as maintaining a good solid ground connection, you could always run a ground wire through and attach it at both ends to ensure a solid ground. That's probably what I would do in this situation.
theatretch85 is offline   Reply With Quote
Old 02-27-2009, 12:06 PM   #5
Rewards Points: 58
Correct, Four prices. Best price = Contract pricing, second = contractors with acct's, third = people like Jamie, fourth = government agencies (without contract).
I always pull an EGC regardless if metal or plastic conduit.
Adding a wall switch to a pull chain fixture abacuslearns Electrical 17 12-20-2011 07:02 PM
Pull boxes / elbows accessable? jamiedolan Electrical 3 02-20-2009 06:18 PM
Pull cord light question 737Pilot Electrical 5 12-21-2008 10:49 AM
No Pull lube jamiedolan Electrical 7 12-16-2008 01:00 PM
Pull / jbox out of A panel box jamiedolan Electrical 5 11-22-2008 12:51 PM
