#1 |
AL ground
Had a question and unsure how to do this without
the NEC states grounding to copper pipe has to be 5 ft or less ,i have bare AL ,and also that it must not be under 18 in of earth.. My copper line coming in at crawlspace is 4 inches above the ground for over 5 ft.. How can i properly ground the wire to pipe without violation..there is a branch off from the main there above 18 inches but its a smaller one coming off the incoming line going to laundry room.Could i ground it there even though its not main line? any info is appreciated Last edited by hidden1; 11-30-2012 at 02:35 PM. |
#3 |
Lic Electrical Inspector
AL ground
It has to be connected within the first five feet of where it enters the building. Size of pipe doesn't matter. Aluminum can't be terminated within 18" of the ground.
All responses based on the 2011 NEC. If you live in New Jersey click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . All other states click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Please check with local, county and state officials as laws may vary. Sizing motors To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online motor calculator To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online calculators To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Last edited by electures; 11-30-2012 at 04:45 PM. |
#4 |
AL ground
that pipe its connected to is over 18 inches and under 5ft from entrance but is teed off of main.
#5 |
AL ground
Good to go.
All responses based on the 2011 NEC. If you live in New Jersey click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . All other states click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Please check with local, county and state officials as laws may vary. Sizing motors To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online motor calculator To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online calculators To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . |
#6 |
AL ground
You question is a little confusing.
Are you installing a Grounding Electrode Conductor (GEC) from your main panel to your main water line? And your GEC happens to be AL? That is what I understand from your post. If that is not the case the answer below will not apply. Your GEC to your Main water line must be connected to your Main water line within 5' of where your water line enters the building. You also need to bond around your water meter. Your AL wire needs to be at least 18" from Earth or Concrete. You can attach to the smaller section after the "T" as long as you meet the requirements above. |
#7 |
Electrical Contractor
AL ground
I remember a job where they required it to be connected to the pipe before any fittings or valves were encountered. At least with the 5 foot rule, you have a bit more accessibility nowadays.
-KB Life is uncertain -- eat dessert first!! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| The Following User Says Thank You to kbsparky For This Useful Post: | electures (12-01-2012) |
#8 |
AL ground
We can't use soldered joints in contact with the ground.
#9 |
AL ground
so as far as location AFTER the T(pipe) it is ok?..that water line goes to a washer
#10 |
AL ground
No problem. Make sure the clamp is listed for AL.
| Display Modes | |
| To ground or not to ground | Red Squirrel | Electrical | 2 | 10-14-2010 09:42 PM |
| Wiring an outlet using both ground screws instead of pig-tailing together. | cabber24 | Electrical | 5 | 08-26-2010 09:40 AM |
| Electrical Ground Problem | cabinetman | Electrical | 15 | 01-28-2010 05:55 PM |
| Live ground wire in dryer | Retired sailor | Electrical | 10 | 05-04-2009 04:26 PM |
| Hot Tub Install--Grounding Rod Question | statgeek_rob | Electrical | 16 | 09-15-2007 03:59 AM |
