Airtight Recessed Lights - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-22-2012, 01:25 PM   #16
Air tight trims
What are air tight trims?
chumley12 is offline   Reply With Quote
Old 01-22-2012, 01:29 PM   #17
Originally Posted by brooker View Post
I have some 1990 juno ic 22 recessed lighting fixture....they are installed in ceiling with insulation...though they have various slots and holes in the cans...i assume that the slots and holes are for other applications...Can I tape them in an effort to reduce infiltration and exfilration????? Currently they have pink( Corning fiberglass) batt insulation around them...which actually does not surround the cans adequately (tightly)....I'm considering packing a loose fill fiberglass insulation ( Guardian e-z fill attic insulation) around them....there ic rated.....like the cooler type closure idea....what do you all think about taping the holes....brooker
I have been told by an "reputable" electrician that you can just plug up the holes in the can with the aluminum tape and it would then a non-IC rated can would become an IC can, but from what I have read, that is not the end of the story.
Old 01-23-2012, 05:45 AM   #18
Yes, I will be looking for airtight trim....what do you think about taping small hole in can...I'm talking slivers of tape 3/8 x 1'' is the largest.....the big air leak was the whole house ceiling fan.... though recently made a cover...and what difference it makes.....in poking around in the attic I see there are slight gaps here and there.... I'm addressing those...
brooker is offline   Reply With Quote
Old 01-23-2012, 09:37 AM   #19
Yes, I well be looking for airtight trim....what do you think about taping small hole in can...I'm talking slivers of tape 3/8 x 1'' is the largest.....the big air leak was the whole house ceiling fan.... though recently made a cover...and what difference it makes.....in pocking around in attic I see there are slight gaps here and there.... I'm addressing those...
Yes. Plugging those holes will make a big difference. Looking at the Commercial Electric "Air-Tight IC cans at Home Depot, all they have done is put a piece of take over the holes in the side of the can. I can see how this would help reduce the loss of the conditioned air in the house, but I don't see how it then becomes an IC can where you are allowed by code to cover the can with insulation. Doesn't there have to be some sort of separation between the can, which gets pretty hot, and the insulation. Isn't that what the insulated box is for?
Old 01-23-2012, 12:27 PM   #20
best I can figure IC stands for insulation contact....the juno recessed light i have.... have a thermal senor on exterior of can..on the top...with plenty of trim and bulb combination posted on interior of can...as well... explains that over heating will result in blinking lights and so on....
Old 02-09-2012, 06:06 PM   #21
Oregon's code re: recessed lighting
I talked to the someone at the Oregon Energy Trust today and he suggested Air Tight Baffles to solve part of the problem of the air infiltration through the recessed ceiling lights with attic space above.
Here is the actual code requirement for non-IC cans in Oregon. I am sure other states have different requirements.
"Existing recessed lights that are not IC-rated may be
found when ceiling insulation levels are increased as part
of a remodel. In these situations, a non-combustible baffle
must be used to keep insulation back and maintain a
three-inch fire clearance around the fixture. The top of the
fixture should either not be covered or maintain a 24-inch
clearance above the top fixture. Code does not require
replacement of existing non-IC rated lights in existing
buildings."
So, it looks like an airtight baffle with a cone made of light sheet metal, foamed in place and left open on the top would solve the problem. Yes?
Old 03-21-2013, 08:53 PM   #22
Several things....
I am an electrician and Now work for a recessed lighting manufacturer.
1. I do not advise altering any openings in the fixture or creating your own barrier
2. The fixture has been tested & rated in a U.L. Registered lab for a specific use. If you alter the fixture you could void the U.L. Rating, which if by chance causes a fire could make you 100% at fault and no insurance coverage will be given
3. Making your own barrier can also create more heat than what is intended for the fixture. Each fixture has a thermal sensor and if overloaded will cause the fixture to no longer work, which means you would have to replace the fixture.
4. Your best bet overall is to replace the fixture with an IC remodel fixture. It is pretty simple to do yourself
Please call a licensed electrician if you are not up to the task!
LightingGuyTexa is offline   Reply With Quote
Old 03-22-2013, 09:39 AM   #23
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Originally Posted by myheadspins View Post
I gave the solution of foam sealants and sealing trim rings to the person that ran my home through an energy audit and he gave me a better solution. He told me to forget the sealing the drywall and trim rings and put one stryrofoam cooler big enough to allow for 3+ clearance around each light and foam the cooler in place. The lights were barely visible in the infrared camera after this procedure. Before the sealing it was mind blowing how much heat I was tossing into the atmosphere.
I can say my lights are really sealed now not just kind of and it wasn't a big deal after moving the insulation around so the coolers could sit right and be foamed correctly. I had to trim some but that wasn't too bad. The outside doors shut way different now without all the holes in the roof. I have IC lights.. I can't even imagine what the old ones would be like.
Neat idea, but I don't recall seeing a UL label on a styrofoam cooler. Maybe I am missing it.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 03-22-2013, 09:42 AM   #24
electures's Avatar
Ah h_ll no. COuld cause more problems then it is worth.
Old 02-28-2016, 01:51 AM   #25
Rewards Points: 2
Air tight recessed lights- Use newer LED fixtures?
I am looking for any newer feedback on airtight recessed lightings.
I have installed over 20 LED 5 & 6" recessed fixtures from Home Depot. One brand is EnviroLite EVL6730BWH27; another is Commercial Electric T65 Recessed LED trim. These adapt to the existing can fixtures with a part that screws into the socket & connects to the LED trim light that fits into the opening & seals against the ceiling
To ensure airtightness, I used silicone around the trim, & foam in the attic around the holes in the light cans, & around the base. I didn't see a heat issue since the LED units are 11 watt maximum output, & I use a dimmer to reduce the output, since they're so bright at maximum. Some of the light cans are IC rated, but most are not, & none are airtight.
I didn't use these cardboard enclosures around the attic light cans, due to the hassle & added expense, once I installed the LED lights.
I realize this is a highly unorthodox approach, but my concern is if there might be any possible safety issue anyone can see.
My ultimate plan is to blow in additional insulation on top of the existing insulation, and completely cover all the light cans, which are not now covered
Any feed back is appreciated.
trekdc is offline   Reply With Quote
Old 03-04-2016, 10:23 AM   #26
Rewards Points: 6
in case of planing to place recessed lights on the top level of your home it is better to use airtight recessed lights to prevent cooled and heated air in your home from escaping to your attic.
tommy16 is offline   Reply With Quote
Installing Recessed Lights IdahoBob Electrical 6 08-23-2007 10:03 PM
Rewiring a switched receptacle to recessed lights b-boy Electrical 4 03-03-2007 07:01 PM
Formula for changing lights to recessed bulbs? Jemo Electrical 12 01-26-2007 05:02 PM
power source for recessed lights Jackman Electrical 1 09-18-2006 07:30 PM
Do I have a Fire Hazard with New Recessed Lights - Help! Christy Electrical 8 05-08-2006 07:31 PM
