Air Handler Hookup - Electrical - DIY Chatroom Home Improvement Forum
Old 07-04-2007, 09:26 AM   #1
Air handler hookup
I am going to run new circuits and wire for my new air handler with built in 14kw heat. I don't know exactly what size/how many circuits to run. I have included an attached image of the tag.
Thanks.
DIYtilIdie is offline   Reply With Quote
Old 07-04-2007, 06:10 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,942
The information is right there.
You can use a single circuit, or two separate circuits.
A single circuit would require overcurrent protection of 80 amps. Wired with #3cu minimum if using NM cable.
If you run two circuits one would need 40 amps protection, the other 45.
14Kw is A LOT of electric heat!
I will STRONGLY suggest having this done by a professional!
DIY Heat Pump/Air Handler replacement hennyh HVAC 62 06-18-2012 05:11 PM
Air Handler to Base gasket/seal?? hennyh HVAC 1 02-04-2007 08:11 PM
Goodman Air Handler with Missing Parts cougarhsv HVAC 2 01-17-2007 08:14 PM
Replacing air handler - How to fit when form factors are slightly different?? hennyh HVAC 2 11-16-2006 08:23 AM
Drainage from air handler jack B HVAC 1 05-07-2006 08:35 AM
