Air Handler/Heat Pump Shut Off Lever - Electrical - DIY Chatroom Home Improvement Forum
Old 11-06-2008, 02:39 PM   #1
Air Handler/Heat Pump shut off lever
Hi,
Are you required to have a shut off lever for an air handler & heat pump if it is within 10 feet of the main electrical box?
Rickl is offline   Reply With Quote
Old 11-06-2008, 04:54 PM   #2
Rewards Points: 2,350
Originally Posted by Rickl View Post
Hi,
Not if the panel is within sight of the device.
Sump pump pit water level --- problem de12 Plumbing 52 01-14-2016 08:46 AM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 10:36 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
Well pump issue-should I be concerned? Mikedks Plumbing 8 10-08-2006 11:42 PM
