Air Cycler Install For Bryant 90 Gas Furnace - Electrical - DIY Chatroom Home Improvement Forum
Old 10-29-2010, 08:08 AM   #1
air cycler install for bryant 90 gas furnace
Have installed air cycler between furnace and thermostat but does not work because it needs common wire connection from furnace to supply power. Bryant does not use a common wire for thermostat.
will a separate 24 vac transformer wired to the common connector on the air cycler do the job?
bill c
bill c is offline   Reply With Quote
Old 10-29-2010, 09:53 AM   #2
Rewards Points: 160
I would need to know what you are talking about before I could suggest anything. Whats an "air cycler" and how do you install it between the furnace and the T-stat.
Model number and manufacturer required. Link would be nice too. Picture?
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Installing a new Furnace, Shoud I install an A/C Coil Now? hartkem HVAC 1 11-10-2008 09:31 AM
How to install an expansion tank in my hot water furnace? DanBress HVAC 18 10-08-2008 03:57 PM
Add-on Wood furnace billmac HVAC 3 06-18-2008 09:17 PM
