Air Conditioning Energy Saver Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 07-25-2008, 04:15 PM   #1
I'm getting killed on my electric bills at my office. The AC units are always being left on. Is their a device that I can install with a key that will stay locked in the cylinder in the on position (to activate the AC) and release in the off position. It will be the same key for the front door so that when people leave for the day, they will have to remove the key - AC goes off - in order to lock the front door???
Any help/ideas greatly appreciated
halo1515 is offline   Reply With Quote
Old 07-25-2008, 05:05 PM   #2
Why not just get a programmable thermostat and lock box?
http://www.honeywell-thermostat.com/...tg511A1000.htm
jerryh3 is offline   Reply With Quote
Old 07-25-2008, 05:08 PM   #3
http://www.nfauto.co.uk/images/oct06/key_switch2.jpg
This type of switch probably can't handle much current so you'd need to tap into a 24vac control line for the AC.
To match the key you need to know what blank (SC1, KW1, SC9, etc.) the door uses and then contact the key switch manufacturer.
http://www.lockpicks.com/index.asp?P...S&Category=293
Doors usually have higher security keys (more pins & tumblers, more complex keyways to keep out picks) than the keys for these type switches.
Vehicle ignition switches have high security, but in my two years cutting keys I hardly ever had a vehicle key blank that matched a building door key blank.
Old 07-25-2008, 06:55 PM   #4
Rewards Points: 6,652
You can go about it two ways. 1) Locking cover over the Thermostat, and programmed to turn to a higher temp during the Summer, and lower in Winter when Office is closed (ie 1/2 hour after lets say office closes @ 5:30, then change temp @ 6 pm, but ramp back up 1/2 hr before opening). Number 2 way, is to use a Internet type Thermostat such as http://www.smarthome.com/_/Thermosta...3/1Sr/nav.aspx that allows you to change from home, or watch changes remotely.
Old 07-26-2008, 11:44 AM   #5
Rewards Points: 160
Timer or programmable T stat. Not accessible to anyone but you.
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 05:06 PM
HVAC energy saver Sappronie HVAC 4 09-06-2007 11:34 AM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
