Air Conditioning - Electrical - DIY Chatroom Home Improvement Forum
Old 04-08-2010, 09:04 AM   #1
Air Conditioning
I live in a trailor and the other day I opened the pannel to the coils and found that there was Ice "from condensation" an inch thick all around them. What causes this? Is it due to low coolant?
Sapper is offline   Reply With Quote
Old 04-08-2010, 09:12 AM   #2
fabrk8r
fabrk8r's Avatar
What was iced...the indoor coil (evaporator) or outdoor coil (condenser)?
fabrk8r is offline   Reply With Quote
Old 04-08-2010, 12:38 PM   #3
Air Conditioner
The inside coils.
Old 04-08-2010, 12:56 PM   #4
fabrk8r
fabrk8r's Avatar
The most common reason evaporator coils (indoor coil, A-coil) ice up is due to restricted air flow, usually caused by a dirty return air filter or because the coil's fins are plugged with dust and hair. If you've already eliminated these possibilities, then yes, the unit may be low on charge.
The only sure way to tell is to hook up a set of gauges and check the high and low side pressures.
Can you see any places on either the indoor unit or outdoor unit (condenser) where there are traces of oil? If so, you will have found a good indication of a possible refrigerant leak.
Old 11-24-2010, 05:38 AM   #5
Hi,
Evaporator Coils are a key part in a central heating and cooling system. In the warmer months when you need air conditioning, the air conditioning condensing unit compresses the Freon in your HVAC system and turns gas into a very cold liquid
Thanks,
with regards
Spam
rozy12 is offline   Reply With Quote
Old 11-24-2010, 10:42 AM   #6
Rewards Points: 204
The defrost cycle is not working most likely. Heat pumps defrost regularly to keep this icing from happening.
Old 11-24-2010, 07:00 PM   #7
dmxtothemax's Avatar
Rewards Points: 5,514
Are the coils clean?
Over time dirt / grease / mould can build up in the fins
of the heat exchanger.
This can reduce the amount of air moving thru the heat exchanger
and they can then ice up.
Ensure there is good air flow thru the coils.
If not clean them with good soap and also bleach if there is
mould build up.
Check the air filter is clean.
I had a simulair problem,
after a good clean with bleach,
the problem was solved.
dmxtothemax is online now   Reply With Quote
My air conditioning (cooling) has gone away guptaalok HVAC 4 05-20-2009 12:43 PM
furnace and air conditioning package price MichaelV HVAC 3 12-02-2008 08:19 AM
Microwave Fan Turns on Air Conditioning - help please Littledj HVAC 16 07-03-2008 08:23 AM
Bryant Air Conditioning Unit ARTLEE HVAC 1 07-01-2007 07:22 AM
Air Conditioning air return hiss during startup craig_dot_net HVAC 2 10-10-2006 08:27 AM
