Air Conditioner Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 04-03-2013, 02:17 PM   #1
air conditioner outlet
Hello my DIY friends,
I need your help. Is it possible to tap into the back of a 220 v dryer outlet to run a feed to a 220 wall air conditioner? The dryer outlet has 4 wires a black, red, white and ground.
Ray
chonchonater is offline   Reply With Quote
Old 04-03-2013, 02:35 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 224
Not legally!
Old 04-03-2013, 04:31 PM   #3
Bill Kearney
Rewards Points: 1,174
Nope. The startup and load drains pulled by those kinds of devices means they both need their own circuit, all the way back to the breaker panel.
Before your friend prices that out, tell him to look into what a mini-split air conditioner setup would cost instead. Those don't usually require 220 and are often much more efficient than a window unit. And just because he might already have a 220 AC unit doesn't mean he should throw good money after bad. Sell it on craigslist (wait until the middle July for the best price) and set up a mini-split instead.
wkearney99 is offline   Reply With Quote
Old 04-03-2013, 05:00 PM   #4
I believe that is what he is going to get, this would only be temporary and the dryer and the window unit would never be on at the same time.
Old 04-03-2013, 06:38 PM   #5
Bill Kearney
Temporary until the house burns down. The answer is still no. 220 like this is nothing to be screwing around with. Really.
Old 04-04-2013, 12:24 AM   #6
dmxtothemax's Avatar
Rewards Points: 5,100
Ray
Is it possible ?
YES.
But is it safe and to code ?
I doubt it !
Like they already said,
Dont be messing with 240v.
it's doubly dangerous.
dmxtothemax is offline   Reply With Quote
Old 04-04-2013, 12:30 AM   #7
Always learning...
fetzer85's Avatar
Rewards Points: 262
Hmm...so this fella doesn't want any a/c when doing his laundry?
That's beyond the point, which as everyone else said, is no way. Although I'm glad you asked here before doing it, it kinda scares me that you thought it was even an option...
fetzer85 is offline   Reply With Quote
Old 04-04-2013, 06:13 AM   #8
kbsparky's Avatar
....this would only be temporary and the dryer and the window unit would never be on at the same time.
Famous last words.....
-KB
Old 04-04-2013, 06:59 AM   #9
Rewards Points: 1,216
No do not do that. Buy a piece of wire and a circuit breaker the correct sizes even if it's temporary /permanent. Wire and circuit breakers are cheaper than life and property.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 04-04-2013, 10:45 PM   #10
TTW
TTW's Avatar
I hope your friend has insurance if he tries this.
Trouble is, the insurance company will deny the claim due to unsafe wiring.
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Outdoor Outlet seansy59 Electrical 3 03-09-2012 04:50 PM
Swithced Outlet to Ceiling Light/Fan Troubles adamiano86 Electrical 7 01-29-2012 10:36 PM
Odd Fireplace Outlet Behavior permagrin Electrical 2 12-17-2011 09:06 AM
Switched outlet series Overkll Electrical 4 12-07-2010 08:38 AM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 09:38 PM
