Air Conditioner Condensing Coil Fins - Electrical - DIY Chatroom Home Improvement Forum
Old 05-03-2011, 08:25 PM   #1
Air conditioner Condensing coil fins
Hey i want to know what the purpose of the Condensing coil fins are, what are they there for anyway does it help with the releasing the heat ?
If they get damaged smashed or whatever do they really affect the condenser
Tony vargas is offline   Reply With Quote
Old 05-03-2011, 11:35 PM   #2
The fins increase the effective surface area of the coils, allowing them to release the heat faster. By effectively trapping air as it goes past the coil, it allows the air to transfer more heat. Thus allowing the evaporator coils at the other end of the system to absorb more heat.
Fin damage will have some effect, but it all depends on how bad the damage is. While the actual maximum output or the air conditioner will be reduced by a certain percentage, oftentimes the loss of performance simply means the unit has to run a little longer to maintain the same temperature, which may use a little more power.
Worst case would be that severe fin damage would result in the system running non-stop and providing very little cooling.
Robo_geek is offline   Reply With Quote
The Following User Says Thank You to Robo_geek For This Useful Post:
Tony vargas (05-04-2011)
Old 05-04-2011, 01:51 PM   #3
Very interesting i really appreciate you taking the time to break that down
great job i fully understand.
condensing coil billmill5050 HVAC 25 05-04-2011 01:20 PM
Damaged fins on furnace EVAP coil rlukas79 HVAC 5 12-21-2010 04:10 PM
Loud vibration of indoor coil in heat mode john-hvac-new HVAC 3 11-03-2009 10:27 AM
Air conditioner evaporator coil keeps icing up applianceman HVAC 2 05-26-2009 08:50 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
