Air Compressor Wiring, Mag, And Pressure Switch To Motor - Electrical - DIY Chatroom Home Improvement Forum
Old 10-08-2010, 06:01 PM   #1
Air compressor wiring, mag, and pressure switch to motor
i have air compressor with 5 HP motor 220 V single ph.
I need help with wiring, I did wire it but something does missing
(I m using white wire as ground)
goranvolvo is offline   Reply With Quote
Old 10-08-2010, 06:23 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
what is the coil voltage of the contactor. If I remember correctly, if you look on the underside (near where the leads to the motor attach) there is a label.
one thing you appear to be missing is anything connected to A2 on the contactor coil. Before you connect anything, you need to know what the coil voltage is.
it also appears you are running your power (to the motor) through the pressure switch. I run the control circuit through switches such as that. It allows the switch to be able to control a lower current.
Old 10-08-2010, 06:44 PM   #3
Right now the voltage is 110 volt on all red wires ,tested with volt meter (there is no label) when I got the box the red wires were already connected , and I did find some info that the power wires donít directly to the motor , so I donít know now Ö
Old 10-08-2010, 06:46 PM   #4
nap
You talking to me?
nap's Avatar
until you determine the coil voltage for the contactor, I would do nothing else.
Hook up the wrong voltage and you will fry it. There will be a label somewhere on the contactor that states what the coil voltage is. You need to find it.
Old 10-09-2010, 11:16 AM   #5
Rewards Points: 240
First why are you using green as a hot wire? The white and black are power source and the green is the ground.
Your coil voltage is determined by looking at the first picture above. Everything you need to wire up this motor is on the drawing inside the enclosure.
If you do not understand this most simple drawing, I suggest you call an electrician.
Old 10-09-2010, 01:15 PM   #6
Retired Electrician
Lsparky is offline   Reply With Quote
Old 10-09-2010, 01:28 PM   #7
Retired Electrician
First get the wire colors right (Green is always Grd.) Use lugs on stranded wire. Rewire the pressure switch to the "coil" so that it can pilot the Mag. The coil MUST be the same voltage as the "Line" in this case 240v. The Pressure Sw. has 4 screws ....use only 2 of them (the 2 on the right OR the 2 on the left. Leave the others unused. Look at the diagraham above carefully. (be sure to check the oil in the compressor)
