| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
Many auto repair kits contain battery-powered air compressors, which can be used to pump up a tire when it goes flat. They are simple to use and don't require much dexterity, though they may pose difficulties if you're not mechanically inclined. Read More »
What Does an Air Compressor Do?
by Expert Village
Hi this is Jon on behalf of Expert Village in this video clip I'll be talking about what an air compressor does. As it's most basic function the air compressor will bring in air from outside it will process that air and it will supply these tanks with... Read More »
Assembling the Air Compressor & Nail Gun
by Expert Village
So we are back with the shoe molding demonstration. We have got all of our pieces cut and in place and fitted. You have got a compressor set up outside and if you are setting up a compressor at home you want the pressure to be between 90 and 110 PSI and... Read More »
How to Change Air Compressor Pressure
by Expert Village
Hi this is Jon on behalf of Expert Village in this video clip I'll be showing you how to properly adjust the pressure for a nematic tool. Now that we have properly hooked up our nematic tool in this case it's a brad nailer we need to adjust the pressure... Read More »
Woodturning Equipment: Power Drill
by Expert Village
In this clip I'm going to talk to you about sanding, specifically power sanding. Power sanding bowls when you're wood turning is a very efficient way to finish your work. And I like to use a variety of methods. One of them is a corded drill. And in the... Read More »
