Air Compressor Starter? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-22-2006, 11:39 AM   #1
air compressor starter?
where is the magnetic starter supposed to be wired? before or after the air pressure cutoff switch? the only diagram i got shows where ot connect the wires.
jamesdart is offline   Reply With Quote
Old 09-22-2006, 02:32 PM   #2
The air pressure switch should go inline with the coil wire to the starter.
With residential modles this should not be a customer concern. It will come pre wired. All you need to do is hook up the supply wires and you are set.
jwhite is offline   Reply With Quote
Old 09-24-2006, 12:14 AM   #3
im builing a compressor form parts. i have a huge devilbiss pump, a big baldor motor, siemens starter and an 80 gallon tank. im not 100% sure on the wiring, so i was hoping for some help.
Old 09-24-2006, 12:50 AM   #4
World famous jerk.
If you post the brand and model of the starter, and the brand and model of the pressure switch, I'll draw you up a wiring diagram.
mdshunk is offline   Reply With Quote
Old 09-25-2006, 03:52 PM   #5
baldor 1409t motor, siemens starter #16CF12bgacq, furnas swicth 69ha2. thank you.
