Air Compressor Popping The Circuit Breaker? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-22-2013, 09:39 AM   #1
Air Compressor popping the circuit breaker?
So I just bought a "new to me" 25 gallon craftsman compressor from a buddy of mine.. The issue is, every once in a while when I turn it on, it pops the circuit so I have to go reset it in the basement.. Does this sound like an electrical issue on the house or on the compressor itself? The house is brand new but im wondering if maybe they put too many accessories on one break because we ran into that before, but also i was thinking maybe there is a short in the electrical on the compressor? Any ideas on what I can check for? Thanks guys.
justwar8806 is offline   Reply With Quote
Old 03-22-2013, 09:44 AM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Is it on its own circuit? What size motor? What size breaker? What size plug on the end of the cord? What size cable?
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 03-22-2013, 12:28 PM   #3
joed's Avatar
Rewards Points: 13,298
What else is on the circuit? It should be on a dedicated circuit for best results.
Old 03-22-2013, 01:00 PM   #4
I have a Campbell Hausfield 26 gallon compressor that I have measured at 13.5 amps.... startup current is much higher for a brief moment. If this is on a 15 amp breaker and there are other things on it the breaker would easily trip at times. Even on a 20 amp circuit it could happen. As suggested it should have its own 20 amp circuit
dan1554 is offline   Reply With Quote
The Following User Says Thank You to dan1554 For This Useful Post:
Speedy Petey (03-22-2013)
Old 03-22-2013, 01:29 PM   #5
Electrical Enthusiast
Rewards Points: 504
probably just an overload situation. You need to reduce the load on that circuit, or plug the compressor into a different circuit.
Kyle_in_rure is offline   Reply With Quote
Old 03-22-2013, 05:12 PM   #6
dmxtothemax's Avatar
Rewards Points: 5,492
Make sure you have the right type of circuit breaker ?
Motors pull a large amount of current breifly when they
first start up. (many times the running current)
This can easily pop a breaker.
you need a dedicated circuit !
and the correct type of breaker !
Some of the older style breakers
were not designed for these applications.
dmxtothemax is offline   Reply With Quote
Old 03-22-2013, 05:20 PM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
Originally Posted by dan1554 View Post
i have a campbell hausfield 26 gallon compressor that i have measured at 13.5 amps.... Startup current is much higher for a brief moment. If this is on a 15 amp breaker and there are other things on it the breaker would easily trip at times. Even on a 20 amp circuit it could happen. As suggested it should have its own 20 amp circuit
this.
Old 03-22-2013, 05:43 PM   #8
Electrical Contractor
kbsparky's Avatar
Originally Posted by Speedy Petey View Post
this.
What??!?
-KB
Old 03-22-2013, 06:07 PM   #9
Originally Posted by kbsparky View Post
What??!?
What I quoted.
does a household circuit breaker have thermal memory? djmieczk Electrical 40 02-10-2013 06:59 PM
Circuit breaker not returning everything to power after switched back on sam112 Electrical 7 02-10-2013 12:48 AM
New wiring tripping breaker on another circuit? Kinggofg Electrical 11 04-26-2012 01:36 AM
circuit breaker? blueandyellow Electrical 7 01-30-2011 10:27 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
