Air Compressor - Electrical - DIY Chatroom Home Improvement Forum
Old 02-27-2011, 01:01 AM   #1
air compressor
i currently have 220 but bought a110/240 compressor i know how to wire the motor my ? is the plug it has a standard 110 plug on the compressor do i just change receptacle or do i need special one
pacercolt is offline   Reply With Quote
Old 02-27-2011, 01:08 AM   #2
" Euro " electrician
frenchelectrican's Avatar
How many HP do your compressor motour have ?
If you going to change from standard 15 amp 120 volt plug to 240 volt plug there is two way you can do is one is cut the 15 amp 120 volt plug off and install the new 240 volts plug { this part some compressor manufacters may not honour the warranty on this matter }
The other option is get a factory 240 volt cord with proper plug on it and the last option is hard wire it.
And make sure you double check the motor connection when you make the change over on voltge and double check the pressure switch as well.
Merci.
Marc
Old 02-27-2011, 04:06 AM   #3
BIGRED
Rewards Points: 252
Don't screw around with it. If you are going to run 240, spend a couple extra bucks and put in an appropriate 240 outlet and appliance cord/plug to match the compressor's 240 locked rotor power rating. Be sure to check your wall wiring for the proper guage for 240 operation as well.
Grampa Bud is offline   Reply With Quote
Heat Pump, dual system, all electric, compressor not working rlc5669 HVAC 16 01-04-2011 08:59 AM
Air compressor and framing nailer for DIY ADKstorm Tools 20 11-11-2010 08:38 AM
Please help: blown fuse, slow compressor fan, and hissing noise from compressor frazwr01 HVAC 10 06-27-2010 10:08 PM
replacing 3 wire to 4 wire compressor fan - please advise! frazwr01 HVAC 2 06-27-2010 11:44 AM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 09:13 AM
