Air Compressor - Electrical - DIY Chatroom Home Improvement Forum
Old 12-07-2009, 06:06 PM   #1
Air Compressor
I have a Air Compressor that has a 1hp motor and its 120/240 VAC. I've hooked it up both ways. Here's my question, on 240 volts it runs just fine but on 120 the motor drags way down and hits a balance point and once it builds up x amount of air it is overwelmed. My question is why?
Livewire78 is offline   Reply With Quote
Old 12-07-2009, 06:24 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
you are changing the wiring inside the motor connection box to make it so it is wired for 120 volts, yes?
Old 12-07-2009, 06:37 PM   #3
The only other connection box is the cut in / cut out . Unless you mean taking motor apart
Old 12-07-2009, 06:41 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,360
Ayuh,... There's wiring changes to the motor, usually under the motor's cover...
Bondo is online now   Reply With Quote
Old 12-07-2009, 07:22 PM   #5
that would explain alot. what do i need to rewire once i get housing off?
Old 12-07-2009, 07:27 PM   #6
Is their a internet link that has a breakdown blueprint on motors?
Old 12-07-2009, 07:44 PM   #7
Originally Posted by Livewire78 View Post
on 240 volts it runs just fine but on 120 the motor drags way down My question is why?
Because you're running on 1/4th the rated power?
Old 12-07-2009, 07:50 PM   #8
what do i need to change?
Old 12-07-2009, 08:49 PM   #9
[quote=nap;363022]you are changing the wiring inside the motor connection box to make it so it is wired for 120 volts, yes?[/quote
How do I do that?
Old 12-07-2009, 09:25 PM   #10
nap
You talking to me?
nap's Avatar
where the cord goes into the motor, there should be a cover plate. There is often a wiring diagram on that plate. If not on the outside, take it off and look inside.
if not on that plate, look at the data plate on the motor. There are generally wiring diagrams on the motor somewhere.
If not, post everything on that data plate and somebody will most likely be able to tell you what to change to make it work.
Old 12-07-2009, 09:48 PM   #11
Old 12-07-2009, 10:38 PM   #12
Idiot Emeritus
Rewards Points: 1,492
If you can't find the connection diagram, post the lead numbers. Usually, they are T1, T2, etc., but be careful, some might be P1, P2, etc.
Rob
micromind is offline   Reply With Quote
Old 12-07-2009, 10:46 PM   #13
Rob
On most motors if it says 120/240 vac, what is the norm for factory wiring 120 or 240, or just it depend on the application? Just so you know I'm pretty sharp on electric, but i'm still learning about motors
Old 12-07-2009, 11:01 PM   #14
nap
You talking to me?
nap's Avatar
it depends on what kind of motor it is.
there is no one standard connection. There are several. If you look for the diagram I spoke of or describe the lead markings, we can probable help but without some help from you, we are guessing.
Old 12-07-2009, 11:33 PM   #15
thanks for all your help, I'm gonna open motor up first thing tommorow morning.
Air compressor and framing nailer for DIY ADKstorm Tools 20 11-11-2010 07:38 AM
Compressor Replacement Lawrence Coppar HVAC 1 06-30-2009 10:50 AM
compressor replacement blues sandman64 HVAC 30 03-22-2009 08:24 PM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 08:13 AM
Fridge compressor convert to air compressor? jogr Appliances 1 04-24-2008 01:10 PM
