After Ceiling Flooding, Light Fixture With Fan Sizzles And Won't Turn On - Electrical - DIY Chatroom Home Improvement Forum
Old 10-28-2011, 09:41 AM   #1
hohadcr's Avatar
Rewards Points: 346
after ceiling flooding, light fixture with fan sizzles and won't turn on
There was a flooding from upstairs, a whole load of washer water came down through the ceiling where the ceiling fan and a light fixture is.
A couple days later now, when I try to turn on the light, the fixture makes a sizzling noise and blinks and won't want to turn on.
Where should I look for the problem? Change a bulb? or do I have to open the ceiling fan box?
Thanks alot
hohadcr is offline   Reply With Quote
Old 10-28-2011, 09:58 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 648
Best bet is to replace the fan and light fixture.
The Following User Says Thank You to jbfan For This Useful Post:
Speedy Petey (10-29-2011)
Old 10-28-2011, 10:40 AM   #3
hohadcr's Avatar
Rewards Points: 346
Totally change the whole thing? Do I need to change the electrical box too?
Old 10-28-2011, 12:50 PM   #4
joed's Avatar
Rewards Points: 13,696
NO but you might need to change the cables if they got very wet. The paper in older cable absorbs the water.
Old 10-28-2011, 01:16 PM   #5
hohadcr's Avatar
Rewards Points: 346
To be clear, I don't need to change the fan and the light fixture, but maybe change all the wiring?
It is an old house with wires rapped in paper and fiber...
How should I decide if the wiring should be changed?
Old 10-28-2011, 02:49 PM   #6
Rewards Points: 760
If the fan and fixture got wet, replace them.
If the wiring got wet, especially the old paper and fiber wrapped wires, call an electrician.
Turn the power off to the circuit until you get it checked.
AandPDan is offline   Reply With Quote
Old 10-29-2011, 02:29 AM   #7
" Euro " electrician
frenchelectrican's Avatar
You have to replace the ceiling fan and luminaire due you got water damage and the other thing I am sure you know about this or not .,, you have to find a way to open up the ceiling to dry it out right away otherwise you may find very damp spot for a while that can created a new issue there.
If you have old cloth NM cable the best bet is call in electrician to assit you on this one.
Merci,
Marc
Old 10-30-2011, 06:19 PM   #8
hohadcr's Avatar
Rewards Points: 346
now everything is working, no noise anymore.
should i still change everything?
Old 10-31-2011, 02:18 PM   #9
hohadcr's Avatar
Rewards Points: 346
Would anyone know....??
