08-01-2012, 03:40 PM
#1
afci trips before gfci?????????
I wired up some out side circuits 20amp gfci outlets with a 20 amp afci breaker when the inspector puts there test tool in the gfci the afci trips and not the gfci......both test normal when you push the test button and work fine under load,but inspector wont pass it. any ideas what could cause this? they are Square D afci's. I double checked all connections and all are tight I am pulling my hair out! please help...
08-01-2012, 03:49 PM
#2
Why is this circuit on an AFCI? I was under the impression that GFI protected circuits didn't require AFCI protection as well. I'm sure someone who knows for sure will be by shortly.
The Following User Says Thank You to LooseSCruz For This Useful Post:
08-01-2012, 03:50 PM
#3
Electrical Contractor
Proper way to test either is with it's test button. Does your area require both, you should just need GFCI for outdoor receptacles.
Usually the manufacturers instructions state the proper way to test is the test button. Not the little inspectors tool.
The Following 6 Users Say Thank You to wirenut1110 For This Useful Post:
08-01-2012, 05:55 PM
#4
E2 Electrician
The ONLY way to test a AFCI or GFCI is with the test button, no other testing tool exists.
The Following User Says Thank You to stickboy1375 For This Useful Post:
08-01-2012, 06:10 PM
#5
Lic Electrical Inspector
The only way to properly test a GFI or AFCI is to follow the manufacturers installation instructions.
All responses based on the 2011 NEC.
If you live in New Jersey click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . All other states click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. .
Please check with local, county and state officials as laws may vary.
Sizing motors To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online motor calculator To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online calculators To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. .
The Following User Says Thank You to electures For This Useful Post:
08-01-2012, 06:20 PM
#6
Ideal makes a tester for AFCI and GFCI circuits...it's just so expensive versus its relative usefulness that I don't think anyone uses them.
But I agree that whatever the manufacturer says is the best option...and that seems to be the good old test button.
08-01-2012, 06:45 PM
#7
E2 Electrician
 better worded than me, thanks.
08-01-2012, 08:04 PM
#8
Semi-Pro Electro-Geek
A stupid inspector. He's doing it wrong. He needs to be pressing the test button on the device, not using his little tester thingy. Since AFCI and GFCI both sense ground faults and only have maximum allowable trip thresholds and clearing times, not minimums, a simulated ground fault tester could trip either one first. It's not a "coordinated system", and it's not required to be. I would normally expect the GFCI to trip first because it's required to have a lower trip current and clearing time, but it's not guaranteed and doesn't indicate a problem.
The Following 3 Users Say Thank You to mpoulton For This Useful Post:
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
