AFCI Tripping - Electrical - DIY Chatroom Home Improvement Forum
Old 09-09-2011, 07:15 PM   #1
AFCI tripping
OK, I have a AFCI tripping the kitchen dinning area and there is 2 lights and recepticles on the circuit. When I plug a sewing machine in or vacumm it trips when both lights are on. I traced the problem back to a switch. As soon as I was unscrewing the plate the plate screw shocked me. One I was in I noticed the ground to the chandlier was directly hooked to the switch and was not connected to the hot leg / other switch for the kitchen light in the switch box. When I connected all the grounds together the chandelier switch would trip the ARC fault. When I opened the chandelier cover the wires were pressed against the box so hard that the wires were exposed so I fixed the problem but the breaker still kept tripping therefore I changed it out with a new ARC fault and now its fine? Do you think I fixed the problem? I don't believe in just changing out breakers to fix a problem but these ARC faults are a pain.
nicholaspierce is offline   Reply With Quote
Old 09-09-2011, 10:56 PM   #2
I=E/R
a7ecorsair's Avatar
You have two open treads for similar problems. I'd venture to say the problem is not the AFCI but something with the building wiring.
When you use the term ground wire are you referring to a white wire or a bare copper wire?
You would not have a ground in switch that goes to the chandelier.
a7ecorsair is offline   Reply With Quote
AFCI circuit is tripping another AFCI nicholaspierce Electrical 8 10-27-2013 03:42 PM
AFCI breaker tripping encounter779 Electrical 8 06-11-2011 05:09 PM
HELP - Strange AFCI Tripping Issue chrispy_g Electrical 40 01-12-2011 11:24 AM
Loss of power and AFCI tripping Sacslc Electrical 14 11-14-2010 10:12 PM
