Afci Is Tripped And Won't Reset - Immediately Trips Again When I Reset It - Electrical - DIY Chatroom Home Improvement Forum
Old 07-13-2012, 10:12 AM   #1
afci is tripped and won't reset - immediately trips again when I reset it
I came home and my bedroom afci was tripped. I try unplugging everything and resetting but it immediately clicks and resets. Should I replace the afci or just call in an electrician? If I was to attempt to replace the breaker, can I just turn the main breaker off in the box and safely replace the afci without frying myself?
serenitynow7 is offline   Reply With Quote
Old 07-13-2012, 10:20 AM   #2
joed's Avatar
Rewards Points: 13,344
Look for a fault on the circuit.
You could test the breaker by removing the wire from and trying to reset it. If it resets then problem on the circuit.
The Following User Says Thank You to joed For This Useful Post:
DangerMouse (07-13-2012)
Old 07-13-2012, 10:23 AM   #3
thank you JoeD. Iím very much a novice here. Remove all the wires or is there a certain one I should try? Also, by turning off the large breaker in the box on the top can I safely work on the rest?
Old 07-13-2012, 10:27 AM   #4
Master Electrician
Turn off your large breaker at the top. Confirm the afci breaker is dead by testing from the screw on the back with the wire hooked to it to ground with a meter. Take the wire off the breaker and put a wirenut on it. Turn the large breaker back on. Reset the afci breaker. If it holds then you have a fault. If it trips then you have a bad breaker.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
The Following User Says Thank You to andrew79 For This Useful Post:
zappa (07-13-2012)
Old 07-13-2012, 10:34 AM   #5
thank you very much for the info. Is it common for afci to go bad?
Old 07-13-2012, 10:40 AM   #6
Master Electrician
Anything's possible. Most likely you have a fault though.
Old 07-13-2012, 10:43 AM   #7
A fault would be a short in the wires? Like an electrical bridge of electricity where there shouldn't be? worn wires etc?
Old 07-13-2012, 10:48 AM   #8
Master Electrician
Yup, you can test for that at the plug as well when the powers off. Using a ohmeter you testing between neutral and hot and hot and ground you shouldn't get a low reading. The meter.
Old 07-13-2012, 10:51 AM   #9
Rewards Points: 3,256
Since it is an AFCI there could also be a loose arcing connection.
zappa is offline   Reply With Quote
Old 07-13-2012, 10:56 AM   #10
For which you probably need to rent Siemens' Intelli-arc device to troubleshoot it.
I come to find out that for the AFCI to detect an arc it needs an arc and at least 5A flowing.
From all the patents on this gadget it's possible they will never eliminate nuisance trips.
Old 07-13-2012, 10:59 AM   #11
If you have AFCI breakers either your home is fairly new, or the wires/breakers have been updated, which is it? How long have you lived in the home?
CopperClad is offline   Reply With Quote
Old 07-13-2012, 01:05 PM   #12
The home is about 2 years old and I have li=ved there for about two weeks.
Old 07-13-2012, 01:34 PM   #13
Are you the first owner? or was it a foreclosure? Reason I'm asking is there's lots of copper thieves and things might have been tampered with and possibly repaired by a hack.. I would guess the breaker would have been tripping the whole time though if that were the case..
Old 07-13-2012, 01:49 PM   #14
gotcha. I'm the second owner but I don't see anything that looks tampered with. Do you think it is worth 30 bucks to replace the breaker myself?
Old 07-13-2012, 01:53 PM   #15
Licensed electrician
Rewards Points: 1,778
Do you do any of the testing shown above?
serenitynow7 (07-14-2012)
