Afci Question - Electrical - DIY Chatroom Home Improvement Forum
Old 02-18-2012, 12:42 PM   #1
afci question
do bedroom circuits have to be afci in michigan?
ruffsawn is offline   Reply With Quote
Old 02-18-2012, 12:59 PM   #2
Depends on what year of the code you are on.
M Engineer is offline   Reply With Quote
Old 02-18-2012, 01:06 PM   #3
Electrician
SD515's Avatar
Rewards Points: 504
Currently in Michigan, AFCI protection is only required for bedrooms, but all outlets have to be protected. Lighting, switches, receptacles and smoke detectors, etc.
FYI, an receptacle is not an outlet. Michigan is on the 2008 code, with a few amendments. AFCI rules are one of them.
Kyle
The Following 3 Users Say Thank You to SD515 For This Useful Post:
DangerMouse (02-18-2012), frenchelectrican (02-18-2012), ruffsawn (02-18-2012)
Old 02-18-2012, 03:46 PM   #4
the Musigician
DangerMouse's Avatar
Yup! What he said ^
DM
Old 02-18-2012, 05:38 PM   #5
Master Electrician
Rewards Points: 3,964
Don't you mean that an oulet is not necessarily a receptacle?
brric is online now   Reply With Quote
Old 02-18-2012, 05:57 PM   #6
Electrician
SD515's Avatar
Rewards Points: 504
Mmm…sort of…in lay-mens terms I suppose. By definition, receptacles are devices, the box the receptacle is mounted into is the outlet (I know you know this). I just like to clarify ‘outlets’ & ‘receptacles’ when talking about them. When AFCI’s first came to be required, there was a lot of job-site talk about what needed to be protected. Some didn’t think that lights and smokeys had to be, they just thought receptacles had to be. But it was proven by the definition of the term ‘outlet’.
Kyle
Old 02-18-2012, 08:59 PM   #7
Rewards Points: 330
article 100 nec:receptacle is a contact device installed at the outlet for the connection of an attachment plug.a single recptacle is a single contact device with no other contact device on the same yoke.a multiple recptacle is two or more contact devices on the same yoke.
recptacle outlet:an outlet where one or more recptacles are installed.
outlet:a point on the wiring system at which current is taken tosupply utilization equipment.
recps are outlets ...
oleguy74 is offline   Reply With Quote
Old 02-18-2012, 09:04 PM   #8
" Euro " electrician
frenchelectrican's Avatar
I just wish the NEC codes rewrite the word outlet to " power point " so it mean it can use to supply the utilzation of the equiment.
The power point is from our French Nomes ( French reguations or French Electrical code ) it the excat same meaning as your word outlet but IMO they ( NEC ) should rewrite it more clear on that.
Merci,
Marc
The Following 2 Users Say Thank You to frenchelectrican For This Useful Post:
a_lost_shadow (02-19-2012), SD515 (02-19-2012)
Old 02-18-2012, 09:08 PM   #9
Rewards Points: 330
Merci,
Marc
if they did that,then we all would know what they were talking about..LOL
The Following 3 Users Say Thank You to oleguy74 For This Useful Post:
a_lost_shadow (02-19-2012), frenchelectrican (02-18-2012), SD515 (02-19-2012)
Old 02-19-2012, 06:51 AM   #10
Master Electrician
Yes they are, the point was that outlets do not have to be receps.
AFCI circuit is tripping another AFCI nicholaspierce Electrical 8 10-27-2013 02:42 PM
AFCI Question baum Electrical 14 08-25-2009 12:27 PM
AFCI breaker question Sheryl Martin Electrical 4 07-06-2009 02:10 PM
Another AFCI Question Bocolo Electrical 17 03-23-2009 08:46 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
