AFCI Problem Has Me Stumped - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 02-23-2011, 09:18 AM   #31
Electrician Canadian Eh!!
Good to hear you found the problem!!!
The AFCI is no different then a GFI breaker but with a different trip rating.
Two coils, one monitors current going out and one monitors current coming back. It trips when there is a difference above the trip point.
I learned ,shortly after they came out, a trick to ensure the neutral is not shared with another circuit or to ensure ground is not touching a neutral.
Simply reverse the hot and neutral on the AFCI breaker and turn on the breaker to see if it trips. If there is no problem then return it to the way it is suppose to be.
hhuggles is offline   Reply With Quote
Old 02-23-2011, 01:13 PM   #32
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
WR_ECE;596328]
Problem was they shared a neutral at the other end, so effectively the hallway light's neutral reference was going through my master bedroom's AFCI (they were both on a single 2-phase wire). Quite a stupid move on the part of whatever electrician wired my house since it was a standard breaker for my lights. It was causing the false-trips (so you got it right nap).
Only real choice I had was to put both circuits through the single AFCI without rewiring that entire circuit. Hopefully it will be ok, I am adding less than an amp to the overall power-draw from the receptacles in my MB. I'll have to get a different breaker for that circuit if they even make them.
what is the manuf and model of the panel? we can try to help with that.
or is there some way to separate the shared neutral? If it is a simple interconnection where both circuits went through a common junction box, you should be able to simple separate the neutrals at that point, obviously being sure the neutral for the circuit fed by the AFCI breaker continues on to the bedroom.
Old 02-23-2011, 01:25 PM   #33
The whole thing is Square D, don't know the specific model of the panel, I'll have to check.
As far as I can tell there is no junction box, but I did not actually go up in the attic/roof to check how the line is fed to those circuits.
WR_ECE is offline   Reply With Quote
Old 02-23-2011, 03:07 PM   #34
nap
You talking to me?
nap's Avatar
so far I'm not finding any 2 pole shared neutral breakers from Square D in any product line.
75 year chimney leak problem mstanleyg Building & Construction 10 03-30-2010 01:38 PM
AFCI circuit breaker bryan1282 Electrical 14 02-11-2010 07:06 PM
UPS & PC combo trip AFCI Keith Wheeler Electrical 12 12-10-2009 08:04 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
