AFCI And GFCI Breakers - Electrical - DIY Chatroom Home Improvement Forum
Old 09-21-2012, 02:30 PM   #1
Rewards Points: 77
AFCI and GFCI Breakers
Do AFCI breakers also provide GFCI protection?
If I were to replace an old 2 prong receptacle with a new 3 prong receptacle, and use an AFCI breaker (and provide appropriate labeling on the receptacle), would this meet code? Or does the receptacle need to be a GFCI receptacle in addition to the AFCI breaker (I am thinking this is the answer)?
Thanks.
patented is offline   Reply With Quote
Old 09-21-2012, 02:42 PM   #2
Licensed electrician
Rewards Points: 1,242
Many AFCI breaker only provide Class B 30 mA GFI protection. This is not the same as the Class A 5mA protection required to protect lives. You could do the AFCI breaker and then install a GFI device downstream.
Old 09-21-2012, 03:01 PM   #3
Rewards Points: 77
Does the class B protection qualify it as GFCI protection under the NEC?
Old 09-21-2012, 03:04 PM   #4
No, the Class B is equipment protection.
patented (09-21-2012)
A few wiring questions (GFCI, AFCI, 2011 NEC) mudworm Electrical 7 10-10-2011 08:32 PM
HELP with GFCI and AFCI problems rs2004 Electrical 10 04-19-2011 07:57 PM
Need help understanding GFCI & AFCI sheslostcontrol Electrical 14 11-01-2010 12:59 PM
Afci & gfci secutanudu Electrical 11 10-13-2009 08:00 AM
code question - AFCI / GFCI breakers Red Squirrel Electrical 15 09-17-2009 12:16 PM
