AFCI Circuit Breakers - Electrical - DIY Chatroom Home Improvement Forum
Old 12-11-2010, 08:10 PM   #1
AFCI circuit breakers
Does the city require AFCI circuit breakers for bedroom circuits?
Skillbuilder is offline   Reply With Quote
Old 12-11-2010, 08:24 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
sure, some cities do. In fact, any city that follows the NEC requires them. Don't know if your city does because you didn't say what city you are asking about.
Old 12-11-2010, 08:32 PM   #3
dSilanskas's Avatar
If your city is under the 2008 code yes they are
dSilanskas is offline   Reply With Quote
Old 12-11-2010, 09:04 PM   #4
Licensed electrician
Rewards Points: 1,794
Actually AFCI protection has been required for portions of bedroom circuits since the 99 NEC.
Old 12-11-2010, 09:24 PM   #5
nap
You talking to me?
nap's Avatar
for portions? The first I remember it, it was "all outlets" in the bedroom. That meant anything from lighting to receps, to smoke/fire alarm outlets that were 120 volt power.
Don't make me go find my 99 code.
as a addendum; Michigan specifically exempted AFCI requirement the first code cycle it was in the NEC.
Old 12-11-2010, 10:13 PM   #6
IIRC it was only for bedroom receptacles when it started. It switched to bedroom outlets later. Therefore my reference to portions of the circuit.
Old 12-11-2010, 10:55 PM   #7
nap
You talking to me?
nap's Avatar
you really are going to make me find my 99, aren't you.
210.12(b)
all branch circuits that supply 125-volt, single phase, 15- and 20-ampere receptacle outlets installed in the dwelling unit bedrooms shall be protected by an arc fault circuit interrupter(s). This requirement shall become effective January 1, 2002.
You win
Installing new load center - do I have to buy AFCI breakers jerseyguy1996 Electrical 6 11-01-2010 09:29 PM
AFCI circuit breaker bryan1282 Electrical 14 02-11-2010 06:06 PM
AFCI breakers BlueBSH Electrical 3 01-09-2010 09:00 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 07:59 PM
Circuit Breakers Unregistered Electrical 4 09-13-2004 08:49 AM
