AFCI Breakers Not Working - Inverter Power - Electrical - DIY Chatroom Home Improvement Forum
Old 05-20-2013, 11:45 AM   #1
Rewards Points: 127
AFCI Breakers not working - inverter power
We have an off grid solar power system at our cottage. A Xantrex 2424 inverter convets 24vdc power to 120 vac modified sine wave power for household use. The 120 v feed into a standard panel. The panel is earthec to two ground rods driven about 18 feet apart. There are AFCIs for the bedrooms per Ontario code. The breakers are not on any recall lisr.
When I push the test buttons, neither breaker trips. They are installed per manufacturers instructions.
Any ideas on why they don't work?
Could the modified sine wave power be the problem?
ptarmigan61 is offline   Reply With Quote
Old 05-20-2013, 12:08 PM   #2
JW
mm11's Avatar
Rewards Points: 596
Is the neutral from the circuit landed on the breaker?
mm11 is offline   Reply With Quote
The Following User Says Thank You to mm11 For This Useful Post:
Philly Master (05-20-2013)
Old 05-20-2013, 07:51 PM   #3
Rewards Points: 127
Yes, and the multi strand wire from the breaker goes to the neutral bus bar.
Power Washer Chem Feed Not Working robertr4836 Tools 11 11-24-2012 09:43 PM
AFCI and GFCI Breakers patented Electrical 3 09-21-2012 03:04 PM
Central A/C not working after power outage rs1971 HVAC 16 04-22-2012 07:39 AM
no power to light switch and all breakers good mjsoma Electrical 4 10-02-2010 10:03 AM
Power inverter AndrewL Electrical 6 03-02-2008 02:43 PM
