Afci Breakers.? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-20-2011, 06:40 AM   #1
afci breakers.?
In a new panel does everthing need to have afci breakers and what is the difference in afci and gfci.?
florpro is offline   Reply With Quote
Old 01-20-2011, 06:49 AM   #2
Rewards Points: 506
Ask you local authority for requirements.
AFCI = arc fault circuit interrupter. Activates in the event of arcing.
GFCI = ground fault circuit interrupter. Activates in the event of a ground fault.
jlmran is offline   Reply With Quote
Old 01-20-2011, 07:22 AM   #3
AFCI Breakers
2011 changes.
The combination AFCI is a circuit breaker that protects downstream branch-circuit wiring as well as cord sets and power-supply cords; an outlet branch circuit AFCI (receptacle) is installed as the first outlet in a branch circuit to protect downstream branch-circuit wiring, cord sets, and power-supply cords.
All 15A or 20A, 120V branch circuits in dwelling units supplying outlets in family rooms, dining rooms, living rooms, parlors, libraries, dens, bedrooms, sun-rooms, recreation rooms, closets, hallways, or similar rooms or areas must be protected by a listed AFCI device of the combination type [210.12(A)]. Figure 210–15
This is for new work.
Old work panel upgrades-good luck with the AFCI breakers. It will depend on your inspector.
Basically if it isn't GFCI then just use an AFCI on new work or rehabs..
See if your insurance company will give you a discount on the AFCI protection. My insurance discount will pay for the AFCI breakers in 5 years.
In basic terms, an AFCI breaker monitors the frequency ( 60 hz) on the circuit. When an arc happens for a certain length of time the frequency is changed and the breaker trips.
A GFCI monitors the current balance on the circuit between the hot and neutral. When that balance is uneven the breaker will trip.
Happy spending,
Bob
Hourglass52 is offline   Reply With Quote
Old 01-20-2011, 11:18 AM   #4
Rewards Points: 3,130
Depends on your location and which version of the code applies. I am in the process of building my own house and the applicable code is NEC 2005. AFCIs are required only for the bedroom circuits. Later code versions require them in more places. Just pray you live where they aren't required everywhere - the price is probably coming down, but they are much more expensive (like 10X) than ordinary breakers.
Can I get AFCI breakers for my panel? BlueBSH Electrical 21 08-04-2010 07:07 AM
Replacing circuit breakers with AFCI ozdiy Electrical 25 07-04-2010 08:09 PM
AFCI breakers BlueBSH Electrical 3 01-09-2010 09:00 PM
code question - AFCI / GFCI breakers Red Squirrel Electrical 15 09-17-2009 11:16 AM
AFCI Breakers Keep Tripping mopowers Electrical 12 09-04-2009 03:11 PM
