AFCI Breaker Requirement - Electrical - DIY Chatroom Home Improvement Forum
Old 08-20-2011, 09:55 PM   #1
AFCI breaker requirement
Hi, I am running a electrical circuit from my circuit breaker panel to a single pole toggle, located inside the house, from there to a pair of Par-38 floodlight, attach the the exterior side of my home.
Does the 2008 NEC code have any requirement, that this be supply by
a AFCI single pole breaker.
I believe it doesn't since the light outlet is outside.
Just another point, I said the on/off switch for the light was inside. what
if this switch was outside.
Please cite NEC 2008 CODE section that would require a AFCI breaker.
Now many thanks to every one the answer this question. THANK YOU!
Ranger31 is offline   Reply With Quote
Old 08-20-2011, 10:54 PM   #2
Code05's Avatar
Rewards Points: 1,104
AFCI not needed. Your circuit is not among those specified.
210.12 Arc-Fault Circuit-Interrupter Protection.
(A) Dwelling Units. All 120-volt, single phase, 15- and
20-ampere branch circuits supplying outlets installed in
dwelling unit family rooms, dining rooms, living rooms,
parlors, libraries, dens, bedrooms, sunrooms, recreation
rooms, closets, hallways, or similar rooms or areas shall
be protected by a listed arc-fault circuit interrupter,
combination-type, installed to provide protection of the
branch circuit.
Code05 is offline   Reply With Quote
Old 08-21-2011, 07:04 PM   #3
msaeger's Avatar
Rewards Points: 260
Do you not need one for a bathroom because the bathroom will have GFCI?
msaeger is offline   Reply With Quote
Old 08-21-2011, 07:42 PM   #4
Electrician
SD515's Avatar
Rewards Points: 504
Currently the code isn't requiring a circuit that feeds a bath to be AFCI protected. But that’s not to say that such circuit doesn’t require AFCI protection. For example, if the bath light circuit is shared with a room that does require AFCI protection, then the entire circuit gets protected. If the circuit only goes to the bath and doesn’t leave, then no AFCI protection is required.
Kyle
Old 08-21-2011, 09:01 PM   #5
msaeger's Avatar
Rewards Points: 260
I am just wondering what the logic of not requiring a bathroom to have it. I was thinking the logic was because the bathroom is required to have GFCI.
Old 08-21-2011, 09:07 PM   #6
Electrician
SD515's Avatar
Rewards Points: 504
The bath receptacles are required to be GFCI'd. The lights are not. Maybe it's the code writers way of admitting that AFCI's & GFCI's don't always play nice together. At least when AFCI's first came out. I'm sure they'll incorparate into future editions though.
Kyle
HELP - Strange AFCI Tripping Issue chrispy_g Electrical 40 01-12-2011 10:24 AM
Wired a new AFCI into my breaker box - 3 questions vseven Electrical 8 01-12-2010 06:55 PM
Loose electrical outlets travishume Electrical 30 08-01-2008 07:21 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
