AFCI Breaker Constantly Trips - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-28-2010, 08:49 AM   #16
Originally Posted by gdweaver View Post
No, I never have to push the test button, I just flip the breaker switch to reset it. All the bulbs are 60 or 65 watts, but they are not CFL's. My wife hates the light that CFL's put out, especially in the bedroom
We have a lot of CFL's
Most of them we have switched to CFL Daylight bulbs
These are actually a different "color" then normal CFLs'
They are a brighter light, not yellow
We have (2) 13w CFL Daylights in the main room & we like them better then the overhead light that has 2 60w reg bulbs
Old 02-28-2010, 02:47 PM   #17
Licensed Electrician
Originally Posted by Five Arrows View Post
Call an electrician. The breaker is there to stop you from melting the wires in your house and setting the thing on fire. Trips daily = WARNING DANGER WILL ROBINSON
Man up and get this fixed before you kill your family
Whether it's tripping on arc-fault or overcurrent, the CB is tripping for a reason. Call a qualified electrician to have it resolved. It might be something as simple as a minor overload of the circuit, but if there's an arcing issue the few bucks spent to pinpoint it could be the difference between peace of mind and a potential fire hazard.
Last edited by Tuckahoe Sparkplug; 02-28-2010 at 02:53 PM. Reason: The main thing is don't keep resetting the CB until fixed.
Tuckahoe Sparkplug is offline   Reply With Quote
Old 02-28-2010, 07:40 PM   #18
Journeyman Wireman
Rewards Points: 150
Tuckahoe,
Just curious, given the information in the first post, how would you go about troubleshooting this problem if you were called out on a service call?
Jupe Blue is offline   Reply With Quote
Old 03-06-2010, 02:12 PM   #19
First, determine what I'm dealing with. The CB doesn't immediately trip, therefore it's not a fault to ground. So is the circuit overloaded or is it tripping on arc-fault? The OP said it trips 'almost on a daily basis'. I'd get everything turned on the circuit and amp it. It's a 15 amp circuit and it normally shouldn't be loaded to more than 80 % (12 amps). If it's reaching 13 or 14 amps the breaker could be gradually building up heat until it eventually thermally trips. In that case, the ambient air temperature around the breaker could also be a deciding factor in how quickly that heat is dissipated and how quickly the CB trips. Anyway, if this turned out to be the problem, I would suggest splitting the circuit by pulling a new one to reduce the load.
If overcurrent was not the problem but it was instead tripping on arc-fault, I would find out if any brushed motors (vacuum, fan, etc.) are being plugged (or hard wired) into the circuit. The arcing from motor brushes can cause some older arc-fault CBs to trip. If this is not the problem, start checking devices on the circuit (particularly switches, as someone else noted) and see if operating them duplicates the problem. Check the terminations on the devices for tightness. No more than switches cost, and probably no more than you would be dealing with, it could be worthwhile to change them out; particularly if the quality of the switches is questionable. Just troubleshoot through the process of elimination.
New Fluorescent Ballast trips GFCI Breaker?? marc515 Electrical 7 02-18-2010 04:42 PM
AFCI circuit breaker bryan1282 Electrical 14 02-11-2010 06:06 PM
900W and up trips breaker, Circuit draws power even with everything off... jasonblu Electrical 40 12-09-2009 02:29 PM
GFCI breaker trips randomly BimmerRacer Electrical 40 09-21-2009 02:11 PM
Table Saw trips breaker - need troubleshooting help Leah Frances Electrical 6 08-26-2009 10:41 PM
