AFCI Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 07-17-2012, 03:31 PM   #1
AFCI Breaker
We had a lightning storm in Alberta the other day and since then none of the receptacles in bedroom works.
The Bed room plugs are on AFCI breaker and when I looked at the panel the breaker was tripped. I tried to "OFF" and then tried to turn it back "ON" as soon as I do that it trips instantly.
First I unplugged everything it didn't solve the issue. Then I disconnected the Hot wire (Black) from each and every plug in all bedrooms no change, breaker keep on tripping when I try to turn it "ON".
Why the breaker keeps tripping even though the receptacles are not even connected? Does this mean AFCI breaker is fried?
On same floor I have GFCI switch installed in batroom and it works fine.
spodey is offline   Reply With Quote
Old 07-17-2012, 03:34 PM   #2
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
Remove the hot wire from the AFCI breaker and try it again. If it trips, replace it.
jrclen is offline   Reply With Quote
Testing outlet on AFCI breaker barley Electrical 11 10-24-2011 11:21 AM
AFCI Breaker Keeps Tripping Muinchja Electrical 30 08-25-2011 04:54 PM
AFCI breaker fullnelson Electrical 1 03-09-2011 04:05 PM
Basement improvement / AFCI Breaker Question BiOs2k Electrical 0 02-25-2011 10:32 AM
AFCI circuit breaker bryan1282 Electrical 14 02-11-2010 06:06 PM
