AFCI On AC Trips Inconsistently - Electrical - DIY Chatroom Home Improvement Forum
Old 08-10-2009, 07:36 PM   #1
AFCI on AC trips inconsistently
I have a portable air conditioner that has an integrated AFCI built into the plug. I can usually use the air conditioner for a few hours then it trips. Other times it trips the second I reset the switch.
I have a hunch the AFCI is tripping on inrush current. It's a fairly big AC.
Could there be a wiring issue? The outlet has been in place for 17 years. The branch circuit is spread out in more ways than I'd like.
I seriously thinking about cutting off the AFCI and using a regular plug.
jefferson.d is offline   Reply With Quote
Old 08-10-2009, 08:17 PM   #2
Google for a service bulletin on this for your make and model. Another thread had the almost identical problem. Search this site for
deus
Old 08-10-2009, 09:02 PM   #3
It's an Amcor PLM.
I don't see anything written about it.
Old 08-10-2009, 09:09 PM   #4
air conditioner tripping at current interrupter
http://www.google.com/search?client=...UTF-8&oe=UTF-8
Old 08-11-2009, 09:23 PM   #5
Electrical Contractor
kbsparky's Avatar
I doubt that is an AFCI device.
It is more likely a GFCI device.
There is a difference.
-KB
Old 08-12-2009, 07:06 AM   #6
The manual says it is an AFCI.
Old 08-12-2009, 07:15 AM   #7
How about a LCDI?
jerryh3 is offline   Reply With Quote
Old 08-12-2009, 07:52 PM   #8
Then I'd think it would be even more prone to nuisance tripping, even it works as it is designed to work. GFCIs are simple compared to AFCIs.
Old 08-13-2009, 09:44 AM   #9
sounds like you have an overloaded circ, aswell as to much inrush current. I've seen window shakers and portables pop breakers AFCI or GFCI. hope this helps but siemans AFCI's have had a few bad batches over the last yr or so. this may help. H
hoppyih is offline   Reply With Quote
AFCI trip when computer turns on tonydiato Electrical 61 09-13-2010 06:24 PM
AFCI and 3-wire circuits...ugghh mhops Electrical 11 03-17-2010 11:22 AM
AFCI trips every 7 days franyzhang Electrical 7 09-26-2008 07:32 PM
Loose electrical outlets travishume Electrical 30 08-01-2008 07:21 PM
New AFCI requirements fw2007 Electrical 16 04-07-2008 08:52 AM
