AFCI _ Just Bedrooms Or All Room - Quebec - Electrical - DIY Chatroom Home Improvement Forum
Old 09-27-2010, 04:32 PM   #1
AFCI _ Just bedrooms or all room - Quebec
Would anyone know if it is required to have AFCI protection just in bedrooms, or is it now require to have in all rooms except kitchen and bathroom. I live in Quebec,canada
dodge1930 is offline   Reply With Quote
Old 09-27-2010, 05:17 PM   #2
Electrician
Rewards Points: 794
According the Canadian Electrical Code only bedrooms need to be AFCI protected, and I beleive it is only the plugs that need the protection and not the lights.
This answer may change if you have something in Quebec that overrueles the CEC.
darren is offline   Reply With Quote
The Following User Says Thank You to darren For This Useful Post:
frenchelectrican (09-27-2010)
Old 09-27-2010, 05:27 PM   #3
Not sure about Canada but the NEC 210.12(B) states:
Dwelling Units. all 120-volt, single phase, 15 and 20 amp branch circuits supplying outlets installed in dwelling unit family rooms, dining rooms, living rooms, parlors, libraries, dens, bedrooms, sunrooms, recreation rooms, closets, hallways or similar rooms or areas shall be protected by a listed arc-fault circuit interrupter, combination-type, installed to provide protection of branch circuit.
The exceptions are any GFI circuits: bathroom GFI's, kitchen: 2 Small appliance branch circuits which should be GFI protected and fire/alarm system
jddavis is offline   Reply With Quote
Old 09-27-2010, 06:02 PM   #4
Rewards Points: 370
wrong thread
MLMIB is offline   Reply With Quote
Old 09-27-2010, 06:07 PM   #5
Originally Posted by MLMIB View Post
any ideas about the PVC as a conduit, is it allowed?
Is it allowed for what? Being used as conduit? Of course it is but im sure it depends on the situation!! And sometimes there are better options than PVC. I like PVC underground or coming out of a soffit.
Old 09-27-2010, 09:03 PM   #6
" Euro " electrician
frenchelectrican's Avatar
Darren .,
sorry to bother ya but I thought the CEC will do cover the luminaires in the bedrooms as well unless I was reading the wrong section of CEC.
Yeah Québec have slightly diffrent code modifactions than the rest of CEC is set up.
Merci.
Marc
Old 09-28-2010, 08:05 AM   #7
Electrician
Rewards Points: 794
Marc the only thing I can find is, receptacles in a bedroom need arc fault protection.
frenchelectrican (09-28-2010)
Old 09-28-2010, 09:31 AM   #8
joed's Avatar
Rewards Points: 12,918
In Ontario only receptacles MUST be AFCI. Lighting is not required to be AFCI but it can be. Smokes must NOT be AFCI.
The Following User Says Thank You to joed For This Useful Post:
Old 09-28-2010, 11:54 AM   #9
Thanks for eveyones input.
With the cost of AFCI breakers $68, is there any problems with supplying two bedrooms (one on the first floor and one in the basement) with one breaker as long as I keep the outlet count to 12 or less?
Also is Canada(quebec) up to the new code in USA where tamper proof outlets are required?
Again
Old 09-28-2010, 02:40 PM   #10
joed's Avatar
No problem supplying more than one room(limit 12). Tamper proof is now required.
Old 09-28-2010, 03:54 PM   #11
Is it still just for bedrooms the AFCI and tamper proof?
Old 09-28-2010, 05:04 PM   #12
Electrician
Rewards Points: 794
Everything needs to be tamper proof except plugs for dedicated microwaves, fridges, freezers, kitchen counters. Plus anything in an attic or crawl space do not need tamper proof.
should the pain in a room match the blinds or be lighter or darker? Wayneious Interior Decorating 3 10-02-2009 05:04 PM
AFCI Question baum Electrical 14 08-25-2009 12:27 PM
Vents from boiler room RammsteinNicCage HVAC 3 03-11-2009 07:28 PM
A room in a room? artosie General DIY Discussions 2 03-10-2009 12:43 PM
AFCI trips every 7 days franyzhang Electrical 7 09-26-2008 07:32 PM
