AF Breaker Stays Tripped - Electrical - DIY Chatroom Home Improvement Forum
Old 09-23-2012, 07:27 AM   #1
AF breaker stays tripped
I wired a duplex building with little assistance from a licensed electrician who would let me do it under his license.
Anyway, I wired two different circuits, one on each side of the duplex. Both circuits are for bedroom plugs which have about 13 receptacles on each circuit. I daisy chained 14-2 from the panel to the plugs and used a 15 amp arc fault breaker. These are two identical circuits, just in different units of the duplex. I got the power turned on to the building and everything worked except these two circuits so I think I must have done something wrong. Any ideAs what it could be? Why would the arc fault breaker stay tripped, is there a chance that a drywall screw may have hit the wire somewhere on both sides causing this?
Thanks in advance.
Cttagl02 is offline   Reply With Quote
Old 09-23-2012, 07:56 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
How is the breaker wired? Did you put the neutral from the circuit to the breaker and the neutral from the breaker to the neutral bar?
Other than that, it could be
Bad breaker
Bad wiring (screw thru romex, bad splice, bad backstab)
Something plugged into the circuit that has a fault.
Old 09-23-2012, 08:02 AM   #3
Yes the neutral from the circuit goes to breaker and neutral on breaker goes to neutral bar.
Old 09-23-2012, 09:25 AM   #4
Rewards Points: 6,652
If the breaker is tripping, and not able to be reset, then you have a short somewhere.
Old 09-23-2012, 10:45 AM   #5
Which could be anything from bad splice or connection, or maybe a screw or nail is making contact with a hot or neutral wire?
Old 09-23-2012, 10:47 AM   #6
Are you asking us, or telling yourself what it could be.
Old 09-23-2012, 10:49 AM   #7
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
All or any one of the above.
sublime2 is offline   Reply With Quote
Old 09-23-2012, 12:20 PM   #8
jrclen's Avatar
Rewards Points: 514
Also, attaching the neutral from the new circuit to a neutral from another circuit can cause the tripping of the arc fault breaker.
John
jrclen is offline   Reply With Quote
The Following User Says Thank You to jrclen For This Useful Post:
gregzoll (09-23-2012)
Room loses electrical, circuit breaker not tripped Wnt2bsleepin Electrical 11 09-07-2011 06:47 PM
Lost all power and breaker not tripped avro1 Electrical 18 02-24-2011 08:57 PM
Tripped breaker installing new light switch? tylermac Electrical 3 02-05-2011 05:57 PM
Breaker tripped after power outage. What's up? Leah Frances Electrical 14 02-12-2009 07:56 PM
Breaker tripped and won"t reset princessme Electrical 8 01-19-2009 08:10 AM
